D4 Light Question
Old Dec 21, 2006 | 09:34 AM
ilpirata78's Avatar
D4 Light Question
Hello Guys,
My first post, thank you for such an informative forum and thanks in advance for your help with my question.
I have changed the bulb for my D4 light however, it's not working
Any ideas what else could be causing this? I know this light is also used for other diagnostics, what should I try next. Has anyone else experienced this?
Your help is greatly appreciated.
96 2.5TL
Old Dec 21, 2006 | 11:52 AM
sushimaster's Avatar
Is this a new bulb? Or did you pull a working one out?
If new, maybe it's just defective.
Have you tried putting in a different bulb with the same results ?
What I did was just take the D2 bulb and stick it in.
Old Dec 21, 2006 | 01:58 PM
daemonicus's Avatar
mine's always been burned out and i've tried putting new ones in there and i also tried switching them with all the other bulbs in the gear cluster. sometimes it just craps out i guess
Old Dec 21, 2006 | 07:47 PM
ilpirata78's Avatar
Hey guys,
thanks for your response. it is a new bulb. I just put in. My problem is that I know this light is also used for some other electronic diagnostics. I just want to make sure everything is ok. I guess i'll go down to my local stealership and see if the can run some diagnostics and find out what's up.
thanks for the response.
Old Dec 21, 2006 | 11:25 PM
TLBaller's Avatar
maybe you used the wrong bulb? Sometimes bulbs fit into a socket but if the model number is diff then it'll blow out fast. Mine burnt out LONG time ago so i took out the gauge cluster and switched the burnt one with the "1" bulb.
Old Dec 29, 2006 | 11:33 PM
dieguinone's Avatar
excuse my ignorance , im just new to the forum and i just get a 1998 3.2 TL , i found this forum browsing the web and i have learned a lot about you guys , and i see that a common problem in this cars is that the D4 light goes out , i have a question , in case that my D4 bulb goes out if i dont change if for a new bulb , what is the worse thing that can happen ? i mean it is very important that light? thanks
p.S.
i just get mi TL like 2 days ago and it came without the user's manual , anybody knows where can i find one?
thanks
(note. the guy who sell me the car, doesn have it either , thanks )
Old Dec 30, 2006 | 09:54 AM
teekay3001's Avatar
Htown slab rider
"I guess i'll go down to my local stealership"...........he said stealership, that just made my day.......LOL
Old Dec 30, 2006 | 03:56 PM
KrayzieDxC's Avatar
Khmer Pride
p.S.
thanks
there really nothing goin to happen, if your use to not seeing a light on the d4 den dont replace it..u can always take out the bulb out for D1 and just replace it in D4 rather then buyin another bulb.
forget the user manual..i have a service manual i upload it last month..use the search bar to downlaod teh manual
and welcome to the forums
Old Dec 30, 2006 | 09:06 PM
dieguinone's Avatar
THANKS KrayzieDxC!!!
thanks god that i found this place
Old Dec 30, 2006 | 10:39 PM
arshdeep99's Avatar
Originally Posted by ilpirata78
Hey guys,
Sorry to hijack the thread but what diagnostics is the D4 used for? Min'es out too but I want to rethink about leaving it like that if it is also a diagnostic light. I don't want to find out later that I could have saved myself a bunch of trouble had a I kept my D4 light running !!
mada51589
Jan 9, 2025 04:40 PM
eastcoastguy
Sep 24, 2015 02:07 PM
wusty23jd
Sep 24, 2015 11:41 AM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
