AC unit making weird noise
I have a 97 3.2TL and i recently took out the AC unit to change out the bulbs. I was sitting in my car testing to see if everything works, which it does..but every time I rotate the temperature knob, i would hear some 'mechanical' adjusting noises.
I also hear a CLICK when i turn on the rear defroster..similar to the clicking of the turn signal.
Now the question is, does this happen with everybody else's TL? Or did I somehow mess something up...?
not sure about the defroster, but the temperature knob thing is normal. whichever way the system has to operate to get to your set temperature, it uses different vents to help cool the car down the fastest. The sound you hear is the vents opening and closing. dunno if that made any sense since i have a headache right now.
'13 Hyundai Sonata
Originally Posted by lg562
That's good to hear. I was starting to think I messed up something after workin on the blue LED conversion in all the front panels
Received 2,329 Likes
Completely normal
大日本帝国
climate control needs FOUR 5mm bulbs and TWO 3mm bulbs
Originally Posted by Big Balla
Thanks you just saved me so much time.
~Cheers~
