abs lights comes on and off
Old Nov 18, 2005 | 03:43 PM
cambo's Avatar
OMG! Oh N0ES!
and you can hear a clicking noise from the front passanger wheelwell. the light will clear if you turn the car off and on and the abs systems runs through its check.
Old Nov 18, 2005 | 03:49 PM
VulgarDisplayOfPower's Avatar
i have the same problem and i am absolutely clueless why this happens.
i'd have to say it's more like a whirring noise, though.
Old Nov 20, 2005 | 06:57 PM
nick96acuratl's Avatar
i had a problem with my abs until i took out the abs motor fuse out never bothered me again. WHO NEEDS ABS ANYWAYS!
Old Nov 22, 2005 | 07:47 AM
My light keeps coming on and off. I did a search in here to see if there was some major issue with it but I came up with nothing. Is this something to be concerned about? Is it costly to repair?
Old Nov 22, 2005 | 06:52 PM
TexasHonda's Avatar
The abs wheel speed sensor may be interfering with the cogged rotor on the CV joint shaft end. My understanding is this would indicate a bearing or other problem w/ wheel assy. If you pull the wheel sensor and end is chewed up, this problem is confirmed. Might be time to have the suspension and bearing checked carefully.
good luck
Old Nov 30, 2005 | 10:21 AM
energyblade's Avatar
4th Gear
Smile
hi, I'm a newbie here and I just got a 96 3.2 tl myself and also experiencing the same issue, the dealer said that it may be the modulator, maybe the accumulator, a sensor or the control unit, but I just wanted to check to see if it is just the wheel sensor. Where is it located and how would I check it? any help is greatly appreciated.
Thx
Old Nov 30, 2005 | 10:30 AM
4th Gear
oh one last thing, I read on another forum that someone had actually taken a integra accumulator / modulator and had installed it directly to fit on a 96 3.2 tl. Can anyone confirm this? Instead of paying over $2200 for each, this may be an option so that we don't have to pay so much.
Old Nov 30, 2005 | 06:28 PM
TexasHonda's Avatar
Wheel sensor plugs into a hole in the wheel hub assembly. A single bolt retains the sensor. Be careful w/ the wire support fixtures and connector.
Have you checked for what ABS codes are presented? This will tell you the likely source of your problem.
Check ebay for used ABS modulators or following link for used units from a local salvage yard. I use this to locate repair parts near me and follow up w/ phone calls.
Car-Part.com
good luck
Old Dec 1, 2005 | 11:23 AM
4th Gear
Smile
Mine is weird, I get the same issue with the ABS coming on and off sometimes, but when I took it to the dealer, they said there was no error codes. They further tested it and said that they could not communicate with the ABS Control unit.
Anyone have any diagrams of where I could check to see if Wheel sensors are located so that I can see if I can clean it or remove anything that might be interfering with it? Thx for the help in advance.
Old Dec 1, 2005 | 07:57 PM
TexasHonda's Avatar
ABS resets itself every time ignition is turned ON. If ABS light is not ON, then no codes are stored. If light is ON, then codes are stored and can be extracted by jumpering the Service Check Connector.
Wheel sensor plugs into wheel hub assy. It's only wire going to the wheel hub assy, so it's hard to miss w/ wheel removed.
good luck
mada51589
Jan 9, 2025 04:40 PM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
Stu2414
Aug 30, 2015 07:30 PM
