ABS light
Old Dec 23, 2006 | 08:37 PM
blackeagle113089's Avatar
ABS light
The ABS light on my dashboard came on a few days ago. I checked the brake fluids and they were fine and i topped them off. The light is still on. anyone have an idea what it could be?
Old Dec 23, 2006 | 08:44 PM
georgy_d28's Avatar
i would start with looking at all the wheel speed sensors to see if they are damaged, if they dont im not sure that you can pull codes off with out a reader
Old Dec 23, 2006 | 08:45 PM
arshdeep99's Avatar
I got my wheel speed sensor replaced.....
https://acurazine.com/forums/showthread.php?t=128649
Old Dec 23, 2006 | 10:24 PM
How do I know if its a wheel speed sensor? Is there one in each wheel?
Old Dec 23, 2006 | 10:34 PM
daemonicus's Avatar
check the manual for the ABS light. it should be in there.
Old Dec 24, 2006 | 08:57 AM
TexasHonda's Avatar
The ABS controller will identify the nature of the problem w/ a diagnostic code.
Code is obtained by shorting the Service Check Connector (2 wire blue connector) under the glove box w/ a short piece of wire. Turn keyswitch to ON and ABS light will flash the codes w/ short flashes and pauses; FFFF-P-FF would be 42. A long pause will separate multiple codes.
Post back for guidance on the nature of the problem or if you have an Acura shop manual you can look up the code.
good luck
Old Dec 24, 2006 | 09:18 PM
arshdeep99's Avatar
Read this thread - TexasHonda helped me out....You'll have to extract the codes and post back for somebody to decipher those codes for you !!
Old Dec 26, 2006 | 02:41 PM
esco786's Avatar
I had this issue with my 2.5 Tl 96 as well. At first it came on, i replaced the ABS accumulator, that cleared the light, but shortly later on the light came back on. Now it just comes on intermittently (very rarely) and usually turning off the car and back on removes it. As well, the 'buzzing' sound for the accumulator comes on many times while I drive which I just ignore.
When replacing the accumulator the mechanic had pointed out the rotting of the 'o-ring' at the base of the accumulator, look for this on the top left section of your hood,there is a cylinder shaped silver accumulator and look for the leaks at the bottom of it...but keep in mind, even if there is a leak, doesnt mean ur accumulator, best thing to do is take your car to a small mechanic shop, and ask them to pull your abs code.
mada51589
Jan 9, 2025 04:40 PM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
Stu2414
Aug 30, 2015 07:30 PM
