ABS light
ABS light
The ABS light on my dashboard came on a few days ago. I checked the brake fluids and they were fine and i topped them off. The light is still on. anyone have an idea what it could be?
I got my wheel speed sensor replaced.....
https://acurazine.com/forums/showthread.php?t=128649
The ABS controller will identify the nature of the problem w/ a diagnostic code.
Code is obtained by shorting the Service Check Connector (2 wire blue connector) under the glove box w/ a short piece of wire. Turn keyswitch to ON and ABS light will flash the codes w/ short flashes and pauses; FFFF-P-FF would be 42. A long pause will separate multiple codes.
Post back for guidance on the nature of the problem or if you have an Acura shop manual you can look up the code.
good luck
good luck
How do I know if its a wheel speed sensor? Is there one in each wheel?
When replacing the accumulator the mechanic had pointed out the rotting of the 'o-ring' at the base of the accumulator, look for this on the top left section of your hood,there is a cylinder shaped silver accumulator and look for the leaks at the bottom of it...but keep in mind, even if there is a leak, doesnt mean ur accumulator, best thing to do is take your car to a small mechanic shop, and ask them to pull your abs code.
mada51589
05-03-2022 08:54 PM
