96 TL rear caliper
96 TL rear caliper
Friends, my next project is replacing rear pads. Using a C clamp seems awkward to use
in compressing the caliper. Is there a simple way to do this ? It looks like a tool is available for
''loan'' at autozone. Recommendations appreciated. rp
96 TL rear caliper
From further reading including the forum; the piston screws into its recess. It isnt compressible in the normal way.
A tool from NAPA, while seemingly well designed, fails in use. It is aluminum and just wont stand the torque.
Continuing.....
Continuing.....
96 TL rear caliper
Auto Zone has a tool 57111 they ''loan''. You buy it and return it. It got the job done .
Regarding the tool; it is steel and has several adapters. The ''T'' handle is a bit under engineered
and I think the thread size could be coarser and stronger. (I'm not a tool maker), but I cant see why a critique
would be out of order. It is worth the effort to simply go get the tool and dispense with ''home remedies''.
kyzzyle (09-29-2021)
loans are free though
If it gets the job done, that's good enough for most..
![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
hondazex
07-08-2010 06:57 AM
