2.5TL radiator (again?)
Old Jan 20, 2004 | 07:21 AM
dkent2's Avatar
8th Gear
Hey I posted here a while ago I have a 1998 2.5TL and I had to replace the radiator at 50K miles. It’s been about a year and last weekend I smelled antifreeze when I got home. It almost looked like antifreeze had been pushed out of the ends of some of the hoses do to pressure or something? I went to an Acura dealer and they checked it out and said everything was ok with the radiator and the hoses. Its been really really cold here in PA I don’t know if this would have anything to do with it. Anyway I think it has something to do with pressure or something. It seems like if the car is driven at higher RPMs the pressure or something causes the radiator to leak around the hose seals? Does anyone have any suggestions as to why this might be happening?
Old Jan 20, 2004 | 08:32 AM
Z Factor's Avatar
I don't know why they wouldn't have done a pressure test on it (maybe they did), but have one done.
Old Jan 20, 2004 | 08:46 AM
dkent2's Avatar
8th Gear
Yea they did do the pressure test and they said everything was ok. Like I said it only happens when the engine reaches high RPMs? That’s my opinion, I still think there is some relationship between pressure/and RPMs or something. Any suggestions?
Old Jan 20, 2004 | 02:46 PM
aznxkaiii's Avatar
speaking of radiator problems, my radiator has a "leak" on the sides of the top. you know where the cap is? well the sides of the radiator....err i know i'm nto being clear at where exactly.
well anyways, radiator = plastic, so i cant use some kind of raditator sealant, it looksl ike it just got loose on those rubber sides.
anyway to close it?
Old Jan 20, 2004 | 04:23 PM
penguinflies's Avatar
could the system be overfilled?
Old Jan 22, 2004 | 07:17 AM
dkent2's Avatar
8th Gear
I don't know what’s going on, this Saturday I am taking to Reading Acura for inspection. There going to check it out more thoroughly then.
Old Jan 22, 2004 | 10:46 AM
Z Factor's Avatar
Just a thought, but were you running your heater at the time?
Old Jan 23, 2004 | 11:35 AM
dkent2's Avatar
8th Gear
yea, the heat was running at the time but what would that have to do with it?
Old Jan 31, 2004 | 10:51 PM
Ogre's Avatar
3rd Gear
your radiator might be cracked. I had the same leaking problem. Dealer replaced the whole thing set me back few couple hundred.
SUcks
Old Feb 27, 2004 | 12:55 AM
just wondering, i got a 96 3.2 premium. i noticed that when i drive somewhere far like a straight 30min. drive my radiator fan goes off and stays on when i turn the car off. the mechanics said that its ok but its so annoying. is there any way to stop it
Old Feb 27, 2004 | 07:45 AM
LDH's Avatar
LDH
I
It's meant to cool your engine off so it doesnt overheat since they had so many problems with legends overheating. So you shouldnt really mess with it.
Old Feb 28, 2004 | 10:33 PM
so does your tl do that too
Old Feb 29, 2004 | 04:02 AM
LDH's Avatar
LDH
I
[QUOTE]Originally posted by sindaygostl
so does your tl do that too [/QUOTE}
yea it does do it too, the harder you run your car the longer the fans are on to cool it off the engine.
Old Mar 4, 2004 | 04:28 PM
CreoleHustla's Avatar
My car does the same thing. I hate that noise , I don't know how to fix it. I got a 1996 2.5 tl.
Old Mar 6, 2004 | 11:27 PM
texcon's Avatar
My radiator began leaking at about 80K miles, and I found a good aftermarket one for about $200 or so. It's common for the top plastic part to spring leaks. Once it begins leaking there, you need to replace it. No need to try and put a bandaid on something as serious as that.
Old Mar 7, 2004 | 09:18 PM
Anyone changed this out therselves
Anyone ever changed out their radiator? I had to add 1/2 gallon on Tuesday or so and then the overflow was empty today and had to top off again. I think that means I havea leak!
TL-Rocket
Dec 4, 2017 06:59 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
2Quik
Sep 21, 2015 08:51 AM
Sep 17, 2015 09:01 PM
NSolace
Sep 3, 2015 08:02 PM
