Upper control arm mounts question
Old May 20, 2025 | 08:26 PM
98ej8's Avatar
Hey all, I'm slowly working on replacing everything on my 04, just haven't posted in a while on my thread.
Question regarding the control arm mounts, has anyone replaced the factory ones with the adjustable ones? Also the upper ball joint, is it worth buying the camber/caster adjustable and do they last or just stick with the regular one since I'm not going lower or anything ?
Thanks for your input
Old May 22, 2025 | 12:07 PM
Acura00RL's Avatar
I replaced both front UCA's in 2019 in my '00 RL and went with regular ( non adjustable BJ's ) units. IMO if your front tires are wearing evenly and normally across the tread width, then there is no need to have BJ adjustable plates (for camber corrections ). I'll let sleeping dogs lie. My 2 cents. FYI, got the units ( Mevotech ) from RockAuto.
Old May 22, 2025 | 01:43 PM
98ej8's Avatar
Thanks I was thinking the same thing. Have the mevotechs held up over the years? I like the price but usually go with other brands because I'm not sure how solid mevotechs are.
Old May 22, 2025 | 05:38 PM
1186KA9's Avatar
Black Ac' Man
Sorry, but as I understand it, there are no aftermarket options for 02-04' RLs. We use a different UCA than the 96-01s, namely the bearings are larger. Maybe try to press out the existing ball joint.
Old May 22, 2025 | 06:10 PM
2000RL's Avatar
Veteran: Navy
I had to go to adjustable upper control arm ball joint after installing lowering springs back in the day on one side to get my camber number within specifications. I went to coil overs last year and needed adjustable ball joints on both upper control arms to get within the correct alignment specifications. Not necessary if your not changing to aftermarket suspension parts.
Old May 23, 2025 | 09:35 AM
Acura00RL's Avatar
45K ( in kms. Vehicle now has 270K ) so far with the Mevotechs ( bought those w/greasable zerk BJ's) and no signs of any trouble. Per 1186KA9's reply, I do not see RockAuto listing any UCA's for '02 - '04 RLs. Did not check if the OEM BJ could be replaced when I did the changeout. Reason for my work was passenger side's one of the pivoting BJ's that attached to fender frame had worn a bit and I got a thumping sound everytime I rode over uneven/washboard ground. If your present UCA's three movable parts are just stiff but without any slop, try injecting some chassis grease w/needle nose attachment. I do this with the Mevotech's two pivoting joints which have no zerks as a PM.
Old May 25, 2025 | 04:40 PM
RxRC's Avatar
I replaced with oem. Needless to say, no issues.
Old May 25, 2025 | 05:20 PM
Acura00RL's Avatar
Thanks for the update. Happy motoring !
Old May 29, 2025 | 08:17 PM
98ej8's Avatar
Thanks for all the responses guys, yeah I was talking about the uca ball joints and the uca anchor bolts, both of those come oem and adjustable style, and the uca ball joint is replaceable so I'm planning on doing that. I'll just got with OEM style thanks!
Ceaze
Aug 4, 2017 07:48 PM
Jmoney6
Jun 20, 2012 12:02 PM
