Reverse Light Wiring
Old Jul 8, 2014 | 04:06 PM
BoostedRL's Avatar
So I'm having an issue with me '00 RL reverse lights and intend to install aftermarket smd LED lights to act as reverse lights instead of stock oem bulbs. The strip I bought has a (+) and (-) wire that is to be connected to the reverse light wiring. My vehicle did not come with a manual and wiring is not my forte. Any chance someone could point me in the right direction as to what power source/wires to tap to make this work out?
thanks!
Old Jul 16, 2014 | 11:46 PM
El-Baz's Avatar
A little late now I guess, but you can buy LED bulbs that just replace the existing bulbs. No wiring needed. Unless the SMD is "wired" for 12V DC, you'll need a current limiting resistor in series with the LED. Without one, you'll burn up your SMD.
Here's the schematic for the B/U lights for an '02. Green w/black stripe is + and the solid black is - (ground)
Old Jul 16, 2014 | 11:50 PM
El-Baz's Avatar
If you have the data sheet for the SMD, you can get the info from it to input into this calculator to get the resistor value you'll need.
http://led.linear1.org/led.wiz
rockyboy
Aug 4, 2024 10:35 AM
cycdaniel
Dec 17, 2019 10:58 AM
Soul_Deamon
Nov 13, 2018 04:44 PM
Soul_Deamon
4G TL Problems & Fixes
Nov 2, 2015 04:32 PM
Mcj270
Aug 31, 2015 04:45 PM
