Loud Noise while switching on my A/C
Hi Gurus,
I have a 98 RL and it is going strong still 178K miles. Recently i noticed a weird noise while switching my A/C on.
Normally on a freezing days, i put the mode as "A/C OFF" and turn On the heater (red)..
while cruising whenever i put "A/C ECON" Mode i am hearing some loud siren noise for around 10 seconds...
This scars the hell out of me...Could you please tell me what might be the problem?
Thanks,
Sh
Thanks,
Sh
Received 2,329 Likes
Bad compressor?
It ONLY does when engaging the A/C?
Check the belts, listen to see if they screech when the A/C comes on.
Might need to have something there fixed or adjusted.
prs2008rl:
I'm almost sure it's coming from the outside air door (behind the glove compartment). The loud noise is actually very common in some RL's and TL's. Replacement would cost you some bucks, otherwise it should be fine, it's just the door getting old. Let me know if you got that taken care of.
Willhiro
Willhiro
hi Willhiro,
i will check the air door as u said. Have u faced this similar problem in ur RL or TL? Also these days i am switching mu A/C off and the lound noise went off....
Biggie_B
02-26-2017 11:14 AM
xsilverhawkx
09-28-2015 06:51 PM
4drviper
09-23-2015 09:00 PM
