What's the trick to the trip-meter reset when you add gas?
I've got it enabled in the MID but it only works about 5% of the time. Lately it hasn't worked at all and I don't know what to do.
I asked my dealership and they said the RDX doesn't have the ability to do it . I didn't want to press the issue it but I will if something is broken. Any ideas what I can do?
Is the trip meter supposed to auto-reset? I don't think so.
I just press and hold the middle button on the right side of the steering console to reset the trip meter. You will have to remember to do it for both A and B (if you care about that).
I kinda like that it does not auto-reset. If you are not filling it all the way up and you are monitoring gas mileage, you would not want it to auto-reset.
The RDX 'does' automatically recalculate your estimated miles remaining when you add gas...
Originally Posted by chipt911
You can set it so Trip A resets with each fill-up. See page 98 of the owner's manual.
Former 07 RDX Tech owner
Mine works every time.
This may not be an issue, but keep in mind that it only resets the A trip meter, the B meter has to be reset manually. I say this because if you switch back and forth between A and B without realizing it then that may account for why it only resets sometimes, no?
I can't fill my own tank here in Oregon, so I'm wondering if you have to fill it up a certain amount for it to work.
edit: do you guys have your rdx completely off when you fill it or do you leave the radio on?
Not filling it full enough would be my guess.
I hate these full serve states. The only time I had someone else fill my tank in the last 20 years or so was one time when I visited NJ - and they forgot to put my gas cap back on. This was a locking gas cap back in the days before they attached them with little rubber leashes - cost like $100 to replace it. Grrrrrr...
Yeah, I know it only resets A but it's not even doing that. I think I will bring it up again the next time I take it in and show them the manual as well.
Fortunately I work right on the border between Oregon & Washington so I'll just drive up on my lunch break to test it out. If that doesn't work, the next time I take it for an oil change I'll show them the manual/MID and tell them to check the sensor. That's the only other thing I can think of that would cause it not to reset.
'07 Moroccan Red Pearl
I am in NJ too. I think its more of a problem with the gas stations trying to top off the tank too much all the time rather than not filling it up. I have yet to set mine up to reset when I get gas but I will soon because now im curious
Mine worked tonight. Trip A reset to zero after getting gas. I turned off the car completely (like I always do anyway) and put in a significant amount of gas (~13 gallons).
soupi
14
11-15-2015 11:15 AM
