Stalls after starting
Old Dec 5, 2022 | 09:15 AM
Jeff Bowyer's Avatar
My 2010 RDX Tech has been working like a champ but the other day it started fine but then stalled out. It took about three tries for it to keep running. Today, same thing. I don't see a thread with anything similar so hopefully it's not a sign of a bigger issue. It's -28 C here today so it'd be nice if I don't have to sit in it to keep it going. I'll put some gas line antifreeze in it to see if it's an ice problem, and will report my results here.
Old Dec 5, 2022 | 11:52 AM
Chopperpilot's Avatar
Could very well be a moisture problem in the fuel system. My advice, from my past experiences, is to keep the tank full, which stops condensation from developing inside the tank . Had this with my diesel tractor with less than a full tank , air condenses to H2O …not good . With gasoline the vapors help displace some air but not all , especially in your colder climate.
Hope this makes sense . Out of curiosity, is your tank full ?
Old Dec 9, 2022 | 11:38 AM
Chopperpilot, after filling with premium (it was previously about half full) I added some gas-line antifreeze. The next morning it stalled after the first attempt, but then kept running after the second one. Same thing yesterday and this morning. So, better, but not as good as it was a week ago. Still searching for answers.
Old Dec 9, 2022 | 09:36 PM
yanga001's Avatar
When you stall out in my expeirience it is due to one of three:
1) Fuel
2) Ignition
3) Air
Are there any check engine lights that come up prior to it stalling? Do you get misfires or total stall. Does it sputter or just completely stall out.
You changed your fuel so the next logical areas within that would be check your fuel pump. Check pressure on the injectors, i am unsure of the process on an RDX but on other vehicles there is a valve stem you can carefully check to see if fuel pressure is maintained.
Ignition in this case refers to spark, immobilizer, etc. Now in this case, this car is run by coil packs so one bad one would normally result in misfires or rough idles. I do not think that is happening here.
Air: check your air filter, is it clogged? Check vacuum lines on the vehicle, are any of them split or loose?
Watch your rpm's next time it stalls out, does it go up and down (bounces), does it drop like a rock, is your idle high or low.
I would say we need a bit more data at this point to get an answer. Sounds like your somewhere in western canada based on those temperatures.
Old Dec 10, 2022 | 01:21 PM
DaIll1's Avatar
If I don't drive daily (to keep the battery up) it acts like that in the cold. The electrical system is weak in these and low voltage causes many issues and a cold battery when it is older will lower voltages.
Old May 30, 2024 | 02:42 AM
Duanewirdel's Avatar
Rdx stalling
Hi.
Old May 30, 2024 | 02:46 AM
my rdx 2007 just started this same thing. I have new battery new alternator and what no. It stalled out on a sharp right turn going into a shopping center w the AC and stereo on. Stereo and ac cut off and car started again right away much bizarro. Moving 500 miles away in six weeks...gotta get this fixed unless its a fluke.
Old May 30, 2024 | 05:29 AM
Could be a battery cable issue with sharp turns .
acacia
1G RDX (2007-2012)
Sep 22, 2014 12:06 PM
acura1972
1G RDX (2007-2012)
108
May 26, 2010 03:51 PM
acura1972
1G RDX (2007-2012)
37
Dec 15, 2009 04:19 PM
gungho_15
1G RDX (2007-2012)
17
Sep 8, 2009 07:15 PM
