RDX Serpentine Belt replacement issues
Old Mar 6, 2016 | 08:01 PM
HondaGuy21's Avatar
3rd Gear
Hey guys,
I've been a long time honda/acura owner - used to be a Honda tech years back and I just want to say the RDX is by far the hardest vehicle to find sh*t for. Acurazine is probably the only place to find any info. But in my searches I haven't found jack on a serp belt replacement. If there is, please post a link and I'll be on my way-I know the drill.
That being said - I have an '07 RDX with 130k and she's been having a vibration/chatter at idle, worse with A/C on. So my first purchase was a belt tentioner kit - found a good deal on Amazon. Once the tensioner was replaced, I started to swap the belt... no bones, belt was SEVERAL inches too long. Advance had a Carquest belt and it was also too long when compared with the old one and O'Riley had a Gates but still too damn long.
Short story long... Do I really have to buy one from the Acura Stealership?
Thanks guys
Old Mar 7, 2016 | 08:04 AM
Jdrum1's Avatar
Have you priced it online?
Given the issues you've had with aftermarket brands, I'd certainly be going OEM.
Old Mar 7, 2016 | 08:10 AM
HondaGuy21's Avatar
3rd Gear
I've found a few OEM belts on EBay for around $40 which I dont mind spending but I want to be positive it will fit.
Old Mar 8, 2016 | 07:33 AM
Jdrum1's Avatar
Have you checked here (or one of the other OEM Acura parts dealers)?
Love eBay, but always leery of car parts.
Acura Parts | OEM Acura Parts | Factory Acura Parts
Old Mar 8, 2016 | 10:09 AM
Tomtwtwtw's Avatar
I would always check the OEM parts websites - they usually have very good pricing (below dealership walk-in). These sites are usually run by dealerships as well, so it's as if you were shopping there anyway, just saving money. For instance, said OEM belt is only $35 from the site above. I also have no idea why it's listed as a power steering pump belt - I only see one belt when I stick my head down there. But maybe double check before you buy.
BELT, POWER STEERING PUMP for 2010 Acura RDX|56992-RWC-A01
Old Mar 8, 2016 | 09:32 PM
wifesRDXtech's Avatar
Originally Posted by HondaGuy21
Hey guys,
Thanks guys
oe Belt here :
Amazon.com: Bando 7PK1732 OEM Quality Serpentine Belt: Automotive Amazon.com: Bando 7PK1732 OEM Quality Serpentine Belt: Automotive
http://acura.bernardiparts.com/Acura/Parts-List.aspx
Old Mar 10, 2016 | 06:00 AM
pjhalifax's Avatar
Was it the 5070683 part number from Advance/CarQuest? I put their "Carquest by Dayco Poly Rib belt" on a couple weeks ago and it was the same length as the original belt I took off. It was enough of a pain in the butt to put on that I'm guessing it wasn't too long. :/
Old Mar 10, 2016 | 06:25 AM
HondaGuy21's Avatar
3rd Gear
I'll have to check that part number. I think all they had was the drive works brand, which is horrible in my opinion. Thanks, I'll check that one out before I order an OE
Old Mar 17, 2016 | 03:18 PM
JasonK's Avatar
09 TL SH AWD /w TECH
Don't use Dayco belts they suck balls. If you havn't already heard.
Use original gates belt. I'll find the part number for you if you need it but do you know roughly what the part number was on the old belt?
Here's part number for Bando & Continental.
Bando - 7PK1732
Continental Kit (Comes with tensioner and belt) -
ADK0044P
Old May 10, 2016 | 10:53 PM
TyB's Avatar
TyB
8th Gear
Did you end up replacing the belt and did it solve your problem? I may have the same issue, which I've been trying to chase down unsuccessfully. Would be awesome if this ended up fixing the vibration.
Old Jul 13, 2016 | 04:20 PM
pdpunome's Avatar
curious about belt part #'s as well. At start up get a nice squeal for a minute then goes awat
EE4Life
Sep 1, 2023 11:05 AM
nx04
Jan 20, 2022 06:14 AM
user 46466648
1G TSX Problems & Fixes
Feb 8, 2017 11:46 AM
tsx_boy
Mar 16, 2016 09:16 PM
joerand
1G RDX DIY & FAQ
Feb 22, 2016 10:13 AM
