Problem already??
Problem already??
I have about 150 miles on my new 08 RDX and for some reason everytime I use the sport (manual) shifting, as soon as I shift from 1st to 2nd, it then shifts to 3rd by itself at only about 4k rpm.....wtf??
Are you sure it isn't simple "shifting" (the engine RPM dropping) via engaging the lockup clutch to attain improved FE..??
I would imagine that if you manually shift into second and then for a few seconds maintain a set speed and relatively constant throttle, gas pedal, position the system will automatically engage the lockup clutch.
Originally Posted by JGard
uh, why not? I exclusively use S mode and shift the car on my own, and I have done so since I bought it.
usually manufacturers tell you not to rev high while the engine is being broken in. I guess you can shift early in S mode but your foot will just ask for more :P
I'll test out the S mode and see if it shifts from 2nd to 3rd, are you guys sure your not in regular D mode and just using the paddle shifters?
Originally Posted by mau108
I wouldn't touch sport mode till the engine has broken in.
something is wrong. it should hold the gear. take it to the dealer.
nothing wrong with using sport mode during break-in, but at the same time, you shouldn't be full throttle with only 150 miles on the vehicle.
Originally Posted by sj993
If you are manually shifting in sport mode it won't upshift for you, it may downshift for you but it won't upshift for you. It does sound like something is wrong.
actually if your on redline for long enough time it will up shift (at least thats what I remember from the manual)
Originally Posted by r7cgb
It should'nt shift automatically to any gear when on S mode.
It's only once you press a paddle that it becomes semi-auto.
As for holding at redline. YES, this car's engine can and will bounce off the rev limiter if you don't tell it to shift. Yes, I've tried it. Yes, it made me extremely happy when it happened.
SidhuSaaB
05-30-2020 12:40 AM
Fool
03-10-2016 08:42 PM
