Key stuck in ignition!
Old May 3, 2007 | 07:14 PM
DDTYM's Avatar
5th Gear
Twice now the key has gotten stick in the ignition. Turns off OK, goes all the way to proper position, but does not come out! The steering wheel does not lock. The shift lever is seated correctly in Park. Took it into the Acura service dept and they were able to get it out after a few minutes; then they could not reproduce the problem. Service manager says he had never heard of this issue. Worked fine for about 6 weeks then it happened again. Has anyone heard of this?
Old May 3, 2007 | 08:55 PM
johnny99's Avatar
Do you have another key that you can try? Maybe the first one is slightly defective.
Old May 4, 2007 | 12:21 AM
sasair's Avatar
This has happened before. Cause was a bad shifter assembly. The vehicle was not registering that it was in park when it was. You can't remove the key unless the vehicle knows it is in park.
Check this thread. Posts number 26-30...
https://acurazine.com/forums/showthread.php?t=733
Old May 4, 2007 | 05:32 AM
DDTYM's Avatar
5th Gear
Happened with both keys. I will bring this shifter assembly comment to the service manager and see what he says....
Old May 15, 2007 | 06:10 AM
Stevenm's Avatar
Acuras since 1988
Is your steering wheel turned all the way in one direction? I couldnt get my key out and when i turned the wheel a little it came right out
Old May 9, 2008 | 03:32 PM
saaricom's Avatar
4th Gear
Bring to dealer there is a recall
I just got it fixed after it happened to me. There is a leak that takes out the fuse on the ignition. Your dealer has an internall memo about this. Get it done before it rains again!
Cheers! Erik
Old May 9, 2008 | 06:00 PM
mau108's Avatar
there is a tsb on that ^
soupi
14
Nov 15, 2015 11:15 AM
eastcoastguy
Oct 29, 2015 03:00 PM
malvothegreat
Sep 29, 2015 12:38 AM
LoneRonin
Sep 28, 2015 09:11 AM
Sue1910
2G CL Problems & Fixes
Sep 27, 2015 12:34 PM
