How to identify source of cabin water
Old Jun 15, 2025 | 09:22 PM
Jackhammer's Avatar
Does anyone have any ideas of how to narrow down where the water inside my cabin floors is coming from? The carpets are constantly wet, mainly on the passenger side but all floor boards are holding moisture.
From research I’ve come across possible seam sealer going bad on roof, or a door or windshield/ wiper cowl gasket, or the evaporator inside the cabin sweating. I’ve adjusted the sunroof so the seal is good, yet water is still entering. I’ve taken apart the passenger a pillar and the drain tube is open, yet on the side of the dash is rust looking as is water was once dripping there.
Old Jun 24, 2025 | 03:17 PM
EasyLoveRDX's Avatar
You mentioned the sunroof drain tube, but what about the spot in the sunroof well where water enters the drain tube?
Only asking because the the sunroof drains clogging here is a very common source of cabin leaks.
Best of luck figuring it out.
Rake
Dec 3, 2021 03:50 PM
Ackack
Oct 10, 2021 05:29 PM
PopaOmero
2G TSX Problems & Fixes
Apr 17, 2020 12:37 PM
y2kardell
Sep 6, 2011 08:57 PM
murky
Jun 2, 2009 07:48 PM
