Heater Core Clogged?
Old Dec 2, 2020 | 07:56 PM
KerryFraser's Avatar
Help!
My heater on my 2010 RDX (base) blows but doesn't heat. One of the hoses that take coolant through the firewall to the core gets warm/almost hot. The other hose stays cold even when the engine is at running temperature. Can I conclude that the core is clogged? Is there a valve somewhere that controls coolant going to the core?
I'm trying to flush the core. Water does not enter the exit (return hose).
The A/C works well.
Old Dec 3, 2020 | 12:35 AM
DaIll1's Avatar
Based on what I see in the diagram, there aren't any valves between the firewall and core. Not changing the coolant at recommended interval can cause the core to plug.
https://www.acuraoemparts.com/v-2010...l--heater-unit
Old Dec 4, 2020 | 12:31 PM
CSmoney28's Avatar
CSmoney28
Acura RDX 5 Door TECH KA 5AT Heater Unit - There is a drain hose click here to see parts lists and diagrams...I would drain it then flush with water and then fill it with oem coolant.
mistryp
1G RDX Problems & Fixes
25
Oct 5, 2024 08:12 PM
ICeZero
1G TSX Problems & Fixes
Mar 2, 2024 04:33 PM
NooYawkuh
3G RDX (2019+)
130
Dec 11, 2021 08:01 PM
jdlikewhoa
Dec 21, 2015 04:40 PM
pnokio
Sep 26, 2012 03:31 PM
