headlight condensation
Old Sep 25, 2025 | 07:52 AM
BlackedOutRDX's Avatar
hello fellow acura-heads!
my 2011 rdx is getting a LOT of moisture in the headlights recently… i dont know if it was because of this headlight restorer kit i got, or if its just because the weather is starting to change.. beats me. I will upload pictures soon, my son was born the other day and we are waiting to be discharged, so i will attach those when i can. I asked my pops what he reccomends to do, and he hit me with the “hairdryer” one word text lol. any other suggestions? much love y’all!!
Old Sep 25, 2025 | 10:15 AM
Chopperpilot's Avatar
I’ve had the same problem with mine and my son’s RDX , both drivers side. . On mine I vacuumed it down with AC vacuum pump to remove moisture and discovered the lenses was leaking at the top . Easy fix was a clear sealer after cleaning of course.
On my son’s, I cheated a bit and used a strip of duct tape and it’s works to this day .
Most headlamps have a vent with some kind of sponge to prevent matter entering the lamp . I would recommend sealing the upper seal and let the heat from the bulbs “burn” off the moisture.
Beats paying over $ 600 for a headlamp for sure ..
Old Sep 25, 2025 | 10:43 AM
EasyLoveRDX's Avatar
Hey congrats on the birth of your son.
Typically the headlight housing just needs to be re-sealed. Lots of youtube videos on how to do this. It's a slight pain since the entire housing needs to come out but definitely doable as a DIY job.
Old Sep 26, 2025 | 07:33 AM
oh god yea, when I saw that they were $2000+ for a brand new set i said “nope” very very quickly, but i’ll go ahead and check out the ducttape trick!!
Old Sep 26, 2025 | 07:35 AM
Thank you so much i will go n pick up a set of headlights at my local junkyard n try out re-sealing on that so i dont gotta drop 2k if i mess up my headlights lol. thank you for the idea, imma try it out!
missingsaga
2G RDX Problems & Fixes
Mar 22, 2025 10:12 PM
Geneg
Jan 21, 2025 12:05 PM
Anovice
Apr 23, 2024 07:06 PM
USCRx
1G RDX Problems & Fixes
Feb 1, 2017 09:28 PM
