check engine and SH awd vsa abs light
Old Aug 14, 2011 | 09:10 PM
sumo6's Avatar
8th Gear
Hey guys
I have 07 RDX tech with CP-E intake I was driving tonight out of no where all the light came on i got a P0102 MAF low input and SH-awd and vas light. so i stop and restart the car the sw awd and the vas light went off just the check engine light still on
I have few ideas about what to do but i would like more ideas
I would
1. change the air filter
2. clean the MAF
3.check the connection on the maf
thanks
Old Aug 14, 2011 | 09:15 PM
wspy's Avatar
2008 Acura RDX
Keep us posted on the cause/fix!
Old Aug 15, 2011 | 12:20 AM
sumo6's Avatar
8th Gear
UPDATE
i have reset the ECU and went on a drive local and highway no light has come on yet will drive more tomorrow
Old Aug 15, 2011 | 04:40 PM
wspy's Avatar
2008 Acura RDX
Was it raining out or very high humidity when it happened?
Old Aug 15, 2011 | 05:44 PM
VietNinjaJ30A1's Avatar
How did you reset your ECU? Don't wanna hijack your thread...I've just been trying to reset mine and I can't. I've disconnected the negative battery terminal for ~10 minutes. That didn't work. I've disconnected the negative battery terminal AND disconnected the connectors on the ECU for ~10 minutes...still didn't work. My radio presets are preserved, my auto-door-lock prefs are preserved
Old Aug 15, 2011 | 07:00 PM
JCRDX11's Avatar
You need to disconnect the neg. first and than the pos. afterward.
Leave it alone or 5 to 10 minutes.
See if that would work or you. (Radio preset has nothing to do with resetting the ECU with the cel/codes that comes up)
Old Aug 15, 2011 | 11:38 PM
sumo6's Avatar
8th Gear
what i did was disconnect both side then touch the CABLE together its like a computer having blue and white screen that reset everything
Old Aug 15, 2011 | 11:40 PM
sumo6's Avatar
8th Gear
UPDATE
Problem fixed
found an bad connection on the pos side maybe the cable moved around when i drove a bump I put on like 200 something miles no light or anything
Old Aug 15, 2011 | 11:47 PM
^^ That same thing happened to me a couple of months after I got my RDX. I saw a few lights come up on the dash and freaked out. Turned my car off and on and everything seemed to be ok. It happened after I hit a pretty good bump. Apparently my positive battery cable was loose.
Old Aug 17, 2011 | 09:20 PM
Kaze66218's Avatar
Copy cat shinobi
Get some clamps from a carstereo shop or amazon. I have a set of Stingers on mine, Acura pissed on all of us by using those wimpy battery clamps.
mada51589
Jan 9, 2025 04:40 PM
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
whitesoxsfan12
Sep 7, 2015 04:07 PM
Stu2414
4G TL Problems & Fixes
Aug 30, 2015 07:30 PM
