Check Engine Light - Code P1717
Old 06-07-2011, 02:22 PM
PM me if you need a reply
InfamousJamous's Avatar
Went to back the car out this morning and noticed the Check Engine Light came on. The D started blinking on the dash. Turned the car off and turned it back on and the D no longer blinked. The CEL stayed on.
She shifted and ran fine with no issues. I then took her to Pep Boys to pull the code and clear it. Here's the code:
P1717 Manufacturer Control Transmission
No issues since then and the CEL did not come on again.
I Googled the code and didn't find anything useful so I thought I'd post this in case anybody else tries running a search. From what I've read, it could have been caused by an issue with the shift lever. I also read that it's an electronic issue, not a mechanical issue. I'm assuming that it's because the shift lever was between gears when I was reversing/forwarding to maneuver out the driveway. I'll follow up if anything.
She does have 141k miles, and yes my gas cap is on tight
PoLuRDX (08-31-2012)
Old 06-07-2011, 02:33 PM
Sorry, should have posted in Problems & Fixes.
Old 06-22-2011, 09:56 AM
mau108's Avatar
141K wow...but one thing have you done a transmission fluid change at sometime ?
Old 06-27-2011, 07:14 PM
Yeah, I flushed it when I bought her at 133k.
Thanks for moving the thread btw.
MikeYutkin
09-10-2015 10:13 PM
Bahamanurse1
09-10-2015 10:05 PM
HeloDown
09-08-2015 06:51 PM
bryan zaragoza
09-08-2015 12:28 AM
whitesoxsfan12
09-07-2015 04:07 PM
Quick Reply: Check Engine Light - Code P1717
