Brake Booster Pressure Sensor
Old Feb 25, 2009 | 09:56 PM
littleblazer's Avatar
On Cold (20F) Morning When I start the car BRAKE WARNING SYSTEM yellow Light come ON.
On my Snapon Solus Pro Diagnostics Scanner code P0556 Came out Brake Booster Pressure Sensor CKT Range/Performance.
Sice I still have warranty took it to dealer to check the sensor and if need it they will replace with new one.
i would do it my self but why pay 100 dollars for sensor.
I'll update what happen. because my RDX still at the dealer. they gave me 09 RL to take home.
Old Jan 24, 2011 | 09:21 AM
fake_usa's Avatar
I know this is an old post but if you're still on the site can you tell me the outcome of this error code.
Thx
Old Jan 25, 2011 | 09:45 AM
gsvette's Avatar
Same thing has been happening to me the last few extremely cold days!
No noticeable signs of a problem (brakes work fine) but amber brake system light is on.
Please let us know what you/dealer found!
Thx
Old Jan 25, 2011 | 12:54 PM
eilros's Avatar
Same thing happened to us last week when the temps were in the -20s. The light came on a few times then but we didn't notice any problems with braking and the light hasn't come on since.
Old Jan 31, 2011 | 07:27 PM
Naten's Avatar
Yeah I have had this same problem over the weekend. It went away on Sunday but came back this morning. Its been in -30 range over night so i'm going to wait it out till it warms up on Thursday before doing anything about it though.
Old Feb 19, 2011 | 09:39 PM
SydKal's Avatar
Brake booster problems
I have had this problem as well...same issues temp-wise and all...different code though P180xx (don't recall the entire code) but says the brake booster may not be working properly and may be harder to press...brakes seem ok...took to the dealer THREE TIMES...after reprogramming the code, checking brake pump, they replaced the sensor...now 6days after having it left it for the weekend the amber light is on again...I am furious. Seems to be somehow cold weather related? The dealer disagrees. I will let you know what happens next.
Old Jan 18, 2012 | 02:31 PM
mrgold35's Avatar
mrgold35
I had this code for the first time ever last weekend when on vacation in Pagosa Springs, CO, when the temps hit 12 degrees in town when we left for the ski resort 35 miles away around 9am. The RDX was slow to start, TPMS was giving me warnings at 26 PSI, Navi screen took forever to brighten up, and the brake booster warning did not turn off until the temp got above 25 degrees (or maybe the engine bay warmed up enough to turn off the code?). Haven’t seen the brake booster error code since that one day and the daily low temps have been above 25 degrees.
I have about +65,000 miles and the brake fluid has never been flushed. Could extremely cold temps and maybe water/contaminates in the brake line(s) caused this error code? If a brake flush is not the answer, how much does it cost to fix?
Old Feb 15, 2012 | 09:05 AM
mrgold35's Avatar
mrgold35
***UPDATE***
Acura tech said the Brake booster sensor voltage was out of specification. It was reading a higher voltage of +7 volts compared to a normal of about 4 volts. Acura replaced and tested. I just have to see if it is A-OK the next time it gets below 10 degrees. I have 66,000 miles on the RDX and wasn’t covered under the powertrain warranty.
Parts: 46401-STK-A01 Sensor, $171.30
Labor: $100
Total: $271.30+free car wash
This was my first unplanned out of pocket expenses for my TSX and RDX. Other than routine maintenance, tires and batteries, both cars have pretty much trouble free and reliable.
Old Feb 15, 2012 | 11:07 AM
DRR98's Avatar
Bad but not super bad $. Hope it stays clear at low temp for you.
Old Jan 21, 2019 | 12:08 PM
Jimhopp's Avatar
Po556 code
My girlfriend has a 2009 Acura RDX and that code flashed when it was cold as well. Last night was -10 degrees here in Michigan and she got into the car again this afternoon and the code is gone,
so I do also believe it is related to cold weather
Old Jan 24, 2019 | 08:21 PM
CSmoney28's Avatar
CSmoney28
Thank you, for the information ℹ️. Thread revivalist you are...
Old Jan 26, 2019 | 09:06 PM
russianDude's Avatar
I keep getting it every winter when it’s 15F or colder. Dealer recommended not replacing anything because it may comeback even with new part. They said there is no problem, it’s just a flaw in the sensor. Could be design issue and the new sensor might not fix it.
Old Jan 27, 2019 | 06:48 AM
mrgold35's Avatar
mrgold35
I haven't had any issues since getting my brake booster sensor replaced back in 2012. I really don't know if replacing the sensor is the 100% solution because my RDX haven't been left out overnight in teens or below since.
Old Jan 27, 2019 | 08:05 AM
cool. My car is 11yr old, and when dealer talked me out of throwing money into new sensor it made sense to me, especially when there is no issue, just faulty sensor. I see it few times a year and it’s really cold, I think I can live with it.
Old Jan 27, 2019 | 10:28 AM
Poveiro's Avatar
I had a similar problem like that wile back, only on extreme cold.
I replaced the DOT and the problem went away, coincidence?
My guess was that to much humidity was already on the DOT and with the change the yellow light went away.
I havent checked at that moment if there's was a code since the light would go off after a wile.
Old Jan 28, 2019 | 09:15 PM
CSmoney28's Avatar
CSmoney28
The hydroscopic fluid for the brake system attracts water into the system. So when the single digits are reached the water in the lines cease up the sensors and cause codes. Sending you to the dealership for new brake hoses due to cracking and new fluid due to the water retention in the system over long periods of time.
Old Jan 28, 2019 | 09:44 PM
No, new fluid will not help this issue in cold. I thought the same thing, and had dealer change my brake fluid, it got colder a month later and the light was back on.
Old Mar 4, 2019 | 12:27 PM
wusty23jd's Avatar
Gosh, I have this same dang issue I think. I've only noticed this cold temperatures, but my wife's brake pedal is starting to feel soft. I did find two codes though:
P16DB & P16DD
https://acurazine.com/forums/1g-rdx-.../#post16392522
Old Mar 4, 2019 | 06:56 PM
P16DB & P16DD
if pedal feels soft its not good, I would have it checked. but if this light only comes on in extreeme cold and everything else is fine with breaks, I would do nothing. The new sensor might not help acording to my service manager if its purely cold related. It might be some sensor design issue they have no fix for.
Old Mar 4, 2019 | 07:38 PM
Poveiro's Avatar
P16DB & P16DD
If feels soft, check for leaks right away.
Air must us got in.
Old Mar 8, 2019 | 08:50 PM
CSmoney28's Avatar
CSmoney28
Check the hoses and fittings. Mine froze once and had to change it.
Old Apr 9, 2019 | 12:26 PM
wusty23jd's Avatar
Update: Brake pedal isn't actually that soft (I think I was just being paranoid), but the codes have returned today in 60 degree weather. I think I may just bite the bullet and bring our RDX to my local Honda dealership to diagnose this issue.
Old Apr 17, 2019 | 06:08 PM
CSmoney28's Avatar
CSmoney28
I would go to acura our RDX is special first of its kind unicorn.
Just my two cents ...
Old May 14, 2019 | 09:40 PM
wusty23jd's Avatar
If anyone else is still following this thread, I found the solution to my problems:
https://acurazine.com/forums/1g-rdx-...-p16dd-977678/
Here are also a few links that describe each code:
Code P16DB
https://www.autocodes.com/p16db_acura.html
Code P16DD
https://www.autocodes.com/p16dd_acura.html
Old Jan 22, 2025 | 08:54 AM
wusty23jd's Avatar
Well, it's -2 degrees in Michigan today and the P0556 code came on. Based on all of the historical comments in this thread, I'm betting it has something to do with the extremely cold weather we're having. I'm noticing no issues at all with braking, so I will give it a few days and see what happens.
Old Jan 24, 2025 | 11:51 AM
wusty23jd's Avatar
Update: On the drive home from work later that day, the "brake warning system" light went away. It's been a few days and the light is still off.
Old Feb 19, 2025 | 11:05 AM
Flapjackura's Avatar
My brake system light came on yesterday. Car is garaged at night - garage usually around 50 degrees in the winter. Temps in my area all day yesterday between -2 and 9 degrees. Car was in an unheated, frigid parking structure yesterday from 8 am to 5:30 pm. Remote started from my office desk at 5:25 pm, made way out to the car, (interior already pretty comfy after about 5 minutes), fully started, backed out of my space, braked, and noticed the brakes felt very soft and un-grabby, enough to make me go "whoa, uh oh!" to myself. Noticed brake system light was on. Wasn't surprised given the "whoa, uh oh" moment. Pumped the brakes a few times, light stayed on. Drove forward a few feet, braked, same soft feeling and need to really shove hard on the pedal to make the brakes grab. The parking brake light also came on, indicating that it automatically didn't disengage. Visions of having to have the car towed or flatbedded to the nearest dealership dancing in my head, I tried shutting the car down and restarting. Presto. Warning light for brake system came on briefly as it always does, then went out. Put in drive, pressed the accelerator gently and the parking brake disengaged normally. Very carefully drove forward and tested the brakes again - felt normal. Did my normal 35 minute drive home and everything felt fine. This morning started up and drove in to the office normally, no weird brake feel and no warning light. Car is in the frigid garage again today, it is expected to be a bit less cold today out.
Should I worry?
Old Feb 20, 2025 | 10:37 AM
EasyLoveRDX's Avatar
Originally Posted by Flapjackura
Should I worry?
How clean is your brake fluid? If clean, I wouldn't worry if the issue doesn't persist. But if it's dirty, good time to do a bleed & fill.
mada51589
Jan 9, 2025 04:40 PM
Yikes
May 3, 2021 04:29 PM
heykosal
1G RDX DIY & FAQ
Nov 16, 2020 03:59 PM
HeloDown
Sep 8, 2015 06:51 PM
NSolace
Sep 3, 2015 08:02 PM
