Air Bag Crash Sensor B1906 code:#2 Feed/Return Circuit Short To Ground
Old Jan 9, 2015 | 07:56 PM
Dominic Galipeau's Avatar
7th Gear
Anyone know where to look to trouble shoot this code ?
B1906 Air Bag Crash Sensor #2 Feed/Return Circuit Short To Ground
Old Jan 9, 2015 | 08:06 PM
7th Gear
Forgot the car !
RDX Tech 2008, 100,000 miles, never accidented.
SRS light on, intermittent, does not seam to be the seat belt as per the OBD2 code.
If it id the crash sensor # 2, Does anyone know where it is located?
Thanks for any advise
Old Jan 10, 2015 | 09:05 AM
7th Gear
Anyone ?
There should have tech expert that know where to look at first to solve the problem ?
Old Jan 10, 2015 | 10:41 AM
acrdr's Avatar
Sensors are usually behind front bumper and around b pillar behind plastic covers
You might have a harness issue or srs control unit failure
Old Jan 11, 2015 | 09:17 AM
7th Gear
Any idea where is sensor # 2 ?
Right or left ?
Old Jan 11, 2015 | 01:49 PM
acrdr's Avatar
Acording to honda
Code B1906 has to do with immobilizer system
Old Jan 11, 2015 | 01:52 PM
acrdr's Avatar
Go to acura and have them read the code
Old Jan 13, 2015 | 03:18 PM
7th Gear
first, Acura have read the code, was B1906
second, B1906 mean:
B1906
Read more: Search Results for b1906 OBDII Trouble Code | Engine-Codes.com
any better answer !
Old Jan 13, 2015 | 03:59 PM
acrdr's Avatar
This is direct from honda
Air Bag Crash Sensor  B1906 code:#2 Feed/Return Circuit Short To Ground-forumrunner_20150113_165823.png
Old Jan 13, 2015 | 04:00 PM
acrdr's Avatar
Srs codes are 2 digit then a dash and 2 digits
Pic for reference
Air Bag Crash Sensor  B1906 code:#2 Feed/Return Circuit Short To Ground-forumrunner_20150113_170004.png
Old Jan 13, 2015 | 04:05 PM
acrdr's Avatar
codes that start with B means is for body control systems
P is for power train .
but hey im just tring to help you out
Old Jan 13, 2015 | 04:06 PM
acrdr's Avatar
sorry for the sideways pic
Old Jan 13, 2015 | 06:11 PM
7th Gear
Thanks, Strange that my link show me Air bag code !
Dealer also confirm what I had found, B1906 Crash sensor #2
Had also a 31-21 code, according to your Site, this lead to this description:high Resistance In Driver Side Impact Air Bag Module
CAn you validate if this is good ?
Old Jan 13, 2015 | 07:54 PM
acrdr's Avatar
Hope this helps
Air Bag Crash Sensor  B1906 code:#2 Feed/Return Circuit Short To Ground-forumrunner_20150113_205403.png
Click image for larger version
Old Jan 13, 2015 | 07:56 PM
acrdr's Avatar
Just some info
Air Bag Crash Sensor  B1906 code:#2 Feed/Return Circuit Short To Ground-forumrunner_20150113_205552.png
Old Jan 13, 2015 | 08:01 PM
acrdr's Avatar
Hope this helps too
Air Bag Crash Sensor  B1906 code:#2 Feed/Return Circuit Short To Ground-forumrunner_20150113_210105.png
Air Bag Crash Sensor  B1906 code:#2 Feed/Return Circuit Short To Ground-forumrunner_20150113_210130.png
Old Jan 13, 2015 | 08:09 PM
acrdr's Avatar
WOW this phone takes crappy pics
Dec 7, 2020 05:39 PM
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
BOOSTED6IX-S
Feb 22, 2016 01:53 PM
PortlandRL
Sep 14, 2015 12:01 PM
