2008 acura onboard computer not ready to be tested
Old Jul 31, 2018 | 04:10 PM
poppy115's Avatar
Hi, i'm having a problem that has stumped several seasoned Acura techs. I went to have my 2008 Acura rdx, inspected and it said that monitor catalyst, monitor evap and monitor oz not ready to be tested. I thought this was because a starter had been replaced more than a month before the test. I then drove more than 1000 miles and had the car retested and still the monitor evap and cat was not ready to be tested. I went to Acura and the tech said he had cleared the two monitors but went to have the car tested all three monitors were again not ready. I guess he just cleared the computer setting me back further. I was then given an exact procedure to follow which i did to a T with not results. Has anyone had this problem or knows of a fix? Should i drive to CA. and back?
thanks poppt115
Old Aug 1, 2018 | 05:15 PM
Tomtwtwtw's Avatar
Hard to believe not all of the readiness checks weren't cleared after that much driving, unless something has been specifically disabled (say, via custom tuning). You can connect a bluetooth OBD reader and use the Torque app, and it'll show you exactly which readiness checks aren't clear. Usually EVAP is the last one to go - most will update after a single drive cycle but EVAP has some specific requirements.
Old Aug 1, 2018 | 06:12 PM
poppy115's Avatar
The last owner was a kid, so that may be a possibly, but i believe we had the car tested once before and it passed. I have unplugged the bluetooth as it did the battery drain thing. Could that be a problem? I can get a regular obd tester will that work? I don't know anything about bluetooth but i can ask my son. Thanks scott
Old Aug 1, 2018 | 09:27 PM
Tomtwtwtw's Avatar
If the previous owner did something like say, turn off the check for a cat because they wanted to run with no cat, the emissions check will *never* show ready. Hopefully that isn't the case, but if so the quickest / cheapest fix might be replacement of the ECU (unless you still have contact with the previous owner).
Terry RL
Jan 3, 2023 05:12 PM
varya
May 10, 2007 03:15 PM
topckret
Feb 11, 2007 12:35 PM
jmichaelp
Jun 2, 2004 02:42 PM
