K23a1 Build
#122
Well she is going under the knife tonight! Crossing my fingers on the install, because I decided to gohead and try the Civic Si RBC cam gear.
bluecarbonfiber (07-07-2014)
DRR98 (07-08-2014)
DRR98 (07-08-2014)
DRR98 (07-08-2014)
#137
looking good!!. was it 1 cam being replaced or both? would think only 1 is needed
#139
bluecarbonfiber (07-08-2014)
#140
8k on this engine won't help you much though unless you have a turbo that can supply the air. Have you found a solution to get more power out of the stock one? With all the other work you're doing it seems like that's going to be your limiting factor.
#141
someone one posted earlier that you can have a wheel changed out i checked around a few turbo shops and its very easy to do if you can get the turbo out.. net you around 30hp increase doing it
#143
Yeah, that was me being to excited. I really don't care about going pass 8k. I told my mechanic that I just want to run 13's and he said "oh it will be a lot faster then 13's."
#144
Amazing.....this is the exact build I had in mind the first time I drove past the Acura dealership, even before we bought ours, before I found this site.
The aftermarket looked bleak for the rdx , you're a true pioneer to have the cojones to throw a bunch of parts not specifically marketed for our ride into one
I'm interested in seeing if the rest of the Drivetrain will hold up lol
KenB350z (07-08-2014)
#146
#147
Haven't found an upgrade for the turbo yet. There is a lot of people here that have information on shops that can upgrade the stock one. I'm going to hold out though. The mechanic wants me to call around and see if any shops can make an adapter for our manifold for an aftermaket turbo or get a sidewinder manifold w/aftermaket turbo and if I could buy an intercooler with a blow off valve delete. So we can run a BOV on the intake charge pipe.
#151
It might be cheaper and easier to have a shop either wield or fit a block-off plate between the stock valve and your current IC. Think solid metal gasket in palace of the stock o-ring.
#160
was the tsx and the rdx tensioner pretty much the same? curious what the difference may be... when will it be tuning day? =)
