Intake
Old 09-15-2016, 11:54 AM
eaglesfan398's Avatar
Intake
Hey everyone!
I received my new intake from TheWrench116 that he had offered to fix! I originally had the knn intake but realized that it was just sucking in hot air from the engine bay cause my car to feel bogged down. When I noticed this TheWrench116 offered to help me and make a custom bend to allow the intake to be mounted in the bottom front of the engine bay. This then allows the car to have fresh cold air in hopes to make more power! Below are some pictures. I would highly suggest that anyone who has a short intake like mine should get it extended. I would contact TheWrench116. Ill post more pictures once its installed but the welds/paint job came out amazing! Thank you again!
Attached Thumbnails Intake-img_2452.jpg   Intake-img_3314.jpg   Intake-img_3316.jpg
TribedazeRDX (11-22-2016)
Old 09-15-2016, 04:53 PM
CrAzYNeSs's Avatar
Josh is great. Looks fantastic - do post pictures when you install it!
Old 09-16-2016, 06:19 AM
Old 09-16-2016, 09:49 AM
hues10's Avatar
Does that mean the CPE one is sucking hot air? It extends further than the K&N and is slightly lower than the battery, instead of sitting on top of the engine bay. But Josh is great. Wish I had his mechanical skills, alas I am just a weekend hacker.
Old 09-16-2016, 10:25 AM
Message Josh! I think he had made an extender for another member with a cpe intake. Don't quote me on it though!
To answer is it sucking in hot air i'm not sure. Do you feel like your car boggs down the longer you drive?
Also another thing to help make the air even colder is cleaning out the intercooler. Its not that hard to take it out and then spray some meguiars wheel cleaner and then hose it off. It makes a world of difference when its clean. Car gets its power back to!
Old 09-16-2016, 11:50 AM
FLETCH
TheWrench116's Avatar
if you compair the k&n and CP-e to the stock setup they are both hot air intakes.
The following 3 users liked this post by TheWrench116:
DRR98 (09-27-2016), eaglesfan398 (09-18-2016), TribedazeRDX (11-22-2016)
Old 09-16-2016, 01:19 PM
WTF?
bluecarbonfiber's Avatar
looks good wrench nice job getting your foot in the door for more options =) now you just need to make a custom piece that goes from the bov to the intake that bypasses the box the factory puts in to reduce sound =) id like to say it also causes a slower reaction but I cant prove it
Old 09-25-2016, 11:07 AM
Haré romel's Avatar
TheWrench116 great job.
Old 09-27-2016, 11:25 AM
6th Gear
kyezrsoze's Avatar
Dang fine work, gonna have to reach out to TheWrench116 when I get past new member status and get some tips on starting my mods off right.
Old 09-27-2016, 11:35 AM
DRR98's Avatar
Nice work Josh.
Mmmm, cold dense air! It's like the difference in pull you feel on a cold winter morning vs a hot summer afternoon.
Another issue that saps power is ic heat soak. Is there a cheap fix?
Old 09-27-2016, 09:55 PM
FLETCH
Originally Posted by DRR98
Nice work Josh.
not really. maybe get an intercooler sprayer?
Old 07-20-2017, 07:45 PM
FLETCH
they say the proof is in the pudding. would you be willing to get the car dynoed with the hood shut as it normally would be during driving? one with the short ram and one with the extension?
Old 07-21-2017, 11:49 AM
heykosal's Avatar
My CPe is sucking hot air. With current outside temperatures, my IAT is around 90 degrees at speed and up to 110+ at idle. Not sure where that temperature is measured though.
Old 07-21-2017, 10:04 PM
9th Gear
007RDX's Avatar
Originally Posted by eaglesfan398
How much does this set up cost?
Old 07-21-2017, 10:18 PM
FLETCH
that temp is measured just below the throttle body on the intake manifold.
Old 07-22-2017, 04:26 PM
heykosal's Avatar
Wow, so even after going through the intercooler it's still that hot. Makes me wonder how hot the actual air coming in through the filter is.
Old 07-23-2017, 03:47 PM
FLETCH
my personal setup and testing is that running a cold air or stock is worth 10-15 degrees cooler air VS a standard CP-e or K&N . and powder coating or painting the intake manifold is worth another 5-10 degrees. I'v had cruising temps of ambient too + 5 degrees.
Old 07-24-2017, 09:13 PM
Haré romel's Avatar
hi, look good, good idea thewrench.
Old 07-24-2017, 09:33 PM
heykosal's Avatar
You a fan of Weyerbacher beers?
Old 07-27-2017, 10:46 AM
FLETCH
never had it...
Old 07-30-2017, 08:47 PM
Billsrdx's Avatar
What is the best CAI to get for the Rdx ? One that will make the most power.
Old 08-01-2017, 12:17 PM
FLETCH
your going to need someone to make you one. Cpe and K&N are both short rams
Old 08-01-2017, 12:42 PM
9th Gear
007RDX's Avatar
With that being said, are you using any particular generic kit for the ones you're making, if you're making them?
That one with the crinkle black paint, which I thought I saw you made in this very thread looks really nice and I'll probably travel that same path. When time comes I hope to exploit that Blouch tubro too.
I just picked up my RDX a few weeks ago and I'm already in love. I used to own an RSX Type S with Honda, I/H/E and love that thing too, so this RDX to me is reminiscent of that car and an old 90 Bronco 2 I used to own which was my first car.
Anyways, I've lurked enough in this website to find a message in which you shared your number so that people could holler at you. I'll likely hit you up once I'm ready to do some things, do you do shade tree mechanic work?
Old 08-01-2017, 09:37 PM
Billsrdx's Avatar
Ok thats what i was seeing that there is only Short Ram intakes and ill never waste money on them , there good for sucking hot air only lol. To bad Injen didn't make one for the Rdx. This post may say this already but you guys that are making intakes are you using 2.75" or 3" pipe? Im not sure how the rdx is set up but my k20 had one sensor on intake which was both intake air temp sensor and maf sensor..Is placement of this on the Rdx critical? Most of us k20 guys ran calibrations off the Map sensor but vit viper eventually switched everyone over to running off the Maf sensor..
Right now im looking to buy a 2009-2012 Rdx but i really want a black one. Ive been reading on these pages alot about the Rdx so this forum has been big help.
Old 08-05-2017, 09:28 PM
heykosal's Avatar
never had it...
It's a local brewery. I'll bring you a case whenever I can make it over to you.
Old 08-19-2017, 07:31 PM
3rd Gear
turbocivicRDX's Avatar
Nice
Old 08-19-2017, 07:35 PM
3rd Gear
my rdx
Old 08-23-2017, 12:26 AM
Billsrdx's Avatar
Intake
Wrench if i payed you would you want to make a intake for me ? I want a true cold air setup . Also i text you earlier with the number you gave me through pm on here .
Old 08-23-2017, 11:58 AM
FLETCH
that is something you would need to post in the black market for a would someone please help me with XYZ
buying or selling outside the black market is strictly prohibited!! it will get threads shut down.
Old 08-23-2017, 11:49 PM
Billsrdx's Avatar
Intake
ok sorry
ExcelerateRep
06-20-2022 09:21 PM
alexbaranyai
19
02-02-2017 06:27 AM
Amitabha
08-09-2016 09:33 AM
6spd-GERCO
22
02-16-2016 07:56 PM
3FIFTY'07TL
02-10-2016 12:14 PM
Quick Reply: Intake
