k23a1-k24a2 head (RBB tsx)
Hi, my ultimate major work.
Bottom stock.
I ll have to go dyno, run so lean now.
Pictures speak for itself:
2009 RDX, 720cc, flashpro, RV6, ZDX flow, skunk2 intake manifold, water intercooler, ARP stud, BC cams, ferrea valve retainer, k24a2 head ported.
Bottom stock.
Bottom stock.
Bottom stock.
THX...
Hi all, I have problem with the exhaust manifold, it broke inside after coolant liquiq by one hose fault, this manifold is very delicate with the temp. I go for aftermarket exhaust manifold. I recommend not do exhaust manifold modification.
Yes, that's not stock, I did turbo upgrade with other company, +70 hp stock housing. There s +100 modifying housing but you have to adapt some parts. I didn t want do modification.
Now, i have big problem, probably i mount t3 turbo as kenb.
:-) Some parts:
- Garrett To4e turbo oil cooled ( Let s see, later i go for ballbearing water-oil cooled gtx30)
- Cast iron manifold
- tial wastegate 38mm
- oil feed kit
- oil drain kit
- oil feed kit
- oil drain kit
Sorry, I was traveling, but I'm done.
Looks same as before
It accelerates fast, feel great, without tuning, I'm just proving reliability, now. But,
turbo load slower 1800rpm oem vs 2500 rpm to4e journal, but excellent after loading.
The external wastegate sounds too much outside, I will connect it to downpipe.
I sometimes have p2263 code, I do not know if I have a bad connection or I need to tune.
I ll check that.
But overall I love it.
I ll check that.
I ll check that.
I ll check that.
Thank you, it would be a good idea to meet, but I'll move out soon, so I'll let you know.
DRR98 (04-03-2017)
Hi guys, external boost control and flashpro low value boost control resolve p2261 code but I ve check engine light on present just p2263 now.
feel good just at 9lb
https://www.youtube.com/watch?v=M9Y1EjqWa2A
Nice, I should have my K20 head in the machine shop this week for a valve job. Can't wait, sounds good!
Cam adv, ign... are very different, i had to work hard in this map. I recommend to work hard in your tuned. Remember you have now factory cam and before you had bc cam, Me bc cam a1, now bc cam a2.
mmm, I dont think so, i m with 11 psi, street fuel, vtec point 7300rpm, 7600 revlimit now it feel very well, i m planning 13 to 15 psi with street fuel to see if engine knock resist. Dont want pay race fuel. i dont have bb turbo (t3 to4e), i would like to install gtx28 gen2 to see if check engine off or gtx30 gen2 for full perfomance.
noraz123
05-15-2020 01:29 PM
