hi need help please
Old 01-26-2015, 08:58 PM
jay0707's Avatar
Question hi need help please
Hi i got a 2007 rdx and i have a backfire problem when shift at high rpg . was wondering if this is normal or not . i have done a few mod on this rdx and not really sure if that cause the backfire problem. the mod are k.n cold air intake,ets intercooler, hks bov, rv6 catless, 3" inch pipe magflow no resonator,and hondata flashpro and thats about it. thanks
Old 01-27-2015, 10:09 AM
Tomtwtwtw's Avatar
Is your BOV venting to atmosphere or back to the intake like the original part? If to atmosphere, during a shift when it blows your car will spike rich for a second, which could cause some fuel to exit the engine and cause a backfire when it ignites in the exhaust.
Also, curious what your injector duty cycle is at with those mods. I think others have said you're pushing it on stock injectors when you combine intake, DP and IC upgrades with Hondata (increase in boost). BUT, I doubt that would cause your backfiring issues. If anything, detonation or misfiring from running too lean.
Old 01-27-2015, 11:11 AM
WTF?
bluecarbonfiber's Avatar
if its not tuned with those mods you could be running dangeriously lean hopefully you arent just running the flashpro with a regular reflash/
next question to bring up is does this happen all the time? ive noticed if the vehicle isnt all the way warmed up it can cause it every now and then..
have you checked to see if there are any codes that have popped up in the flashpro due to this?
Old 01-27-2015, 07:09 PM
jay0707's Avatar
My bov is vent to atmosphere and yes my injector. I'm so lost This have not happen befor
Old 01-27-2015, 07:15 PM
jay0707's Avatar
Nope I have flashing done each time I installed new parts by a flashing expert. Not getting any code on this bam. My old code that I got is p0234 overboost which got it fixed just waiting for new boost gauge. My mechanic said . The stock boost gauge is dangerous not showing how many boost giving and no light warning so yeah. Thanks for replying
Old 01-27-2015, 07:16 PM
jay0707's Avatar
I am planning on getting those 800cc injector
Old 01-27-2015, 07:26 PM
WTF?
change your bov to be full recirculation see if that helps
Old 01-27-2015, 07:34 PM
jay0707's Avatar
today I went fast aND shift around 6500 7000 rpm and no bam. It doesn't seem to happen all the time tho
Old 01-27-2015, 07:38 PM
jay0707's Avatar
Do you think it might be the air intake filter cause that the bthe bam happened once after I changed the k.n. Filter to a dry filter. I took the k.n. Out so I could wash it
Old 01-28-2015, 09:44 AM
Tomtwtwtw's Avatar
So...before you start doing all kinds of things, do as blue said and change your BOV to recirc. Atmospheric valves will almost always cause problems (especially backfires, among other things) when tuning is not adjusted for them, for the reason I gave above. Either that, or find out how to adjust your tune so that it compensates for your atmospheric valve, although I'm not sure if the Flashpro has tables unlocked for that. *IF* that doesn't work, then dig further.
Old 01-29-2015, 09:01 AM
RDX faN BoY
rdxchris710's Avatar
can we run our bov's to the atmosphere without any real issues besides a backfire here and there which i don't mind? I know on my old galant vr4 it would stall right out if you tried to vent it.
Old 01-29-2015, 09:12 AM
Tomtwtwtw's Avatar
Well if you have a cat, you run the risk of rendering it useless. Otherwise I don't think there is any major issue aside from you occasionally spitting a bit of fire out your exhaust. I suppose it *might* prematurely wear or foul your spark plugs, but I honestly don't think the rich spikes are bad enough for that. Pretty sure the fuel just moves right through the cylinder and into the exhaust. That is just my speculation though.
Old 01-29-2015, 10:58 AM
WTF?
back in the day when people where first adding a BOV to the RDX they found that it needs to be atleast 80% recirc otherwise it will cause issues.. which could be backfiring, running to rich, car hesitation, sometimes vehicle dies due to AFR ect.. your safe bet is to run full recirc and just have a good aftermarket intake so you can hear the BOV that way
Old 01-29-2015, 02:26 PM
Tomtwtwtw's Avatar
^^^ What he said...I should have specified - should be no problem in terms of damage risk. You may have issues with it running smoothly.
Old 01-29-2015, 09:39 PM
jay0707's Avatar
hi thanks for all the replys all this info helps alot but my bov was done way ahead of times . first i changed to turbosmart 50/50 and then once i got flashpro i just went for full atmosphere alot of programing on flashpro and rework on the hood to really make it work without killing engine or backfire . i notice backfire after the overboost code fix. im still waiting for my aftermarket boost gauge to install. my mechanic say ill need further tune up on flashpro again. all those flashpro tune up are done on street . i might ask for dyno tune once i got those 800cc injectors but i had few question befor getting those. thanks
Old 01-29-2015, 10:00 PM
KenB350z's Avatar
If you're going for sound, just get an s pipe like this one. It's makes the BOV louder for sure!
Old 01-29-2015, 10:14 PM
jay0707's Avatar
nice ets intercooler ken . ken i think you are way ahead of everyone . im so looking forward to your finish build. as for me i still new to this stuff. infact i might stop once i get to my finish wishes. someday maybe ill video my ride.. and show everyone about my little build. man i wish we can have a front intercooler .. as anyone done that ? or even changing 15t to 18t ?
Old 01-29-2015, 10:16 PM
jay0707's Avatar
my bov is loud enough . i installed hks bov (silver)
Old 01-29-2015, 10:18 PM
KenB350z's Avatar
Thanks, just trying to be here for everybody and keep doors open for the RDX. I'll take some pictures of the section for the front mount intercooler, so everyone can see why it may not work for our chassis.
Old 01-29-2015, 10:34 PM
KenB350z's Avatar
This is the route of the RSX and Civic that the intercooler piping goes, as you can see it's not open on the RDX. You will need to cut for sure.
Old 01-30-2015, 07:42 PM
jay0707's Avatar
ok just went to my buddy mechanic and my boostgauge is here just waiting for my appointment which is on friday. i was gonna order those 800cc injectors but my mechanic say i would need to change my pump. i was wondering if anyone doine those injectors with stock pump?. i end up getting 600cc injectors which getting those done on same days. so can do some flashpro after installed those two. and then i order those drilled and slot rotors from ebc . bought all 4 rotors with pats changing fuild to dot4 abs and those blake lines . what you guys think? ill post some pictures once i got all those done . i hope all this mod are not making me look rice .
Old 01-30-2015, 07:48 PM
jay0707's Avatar
p.s. ill have to say those injectors and brakes are not soo cheap >.< big kills
Old 01-30-2015, 10:31 PM
KenB350z's Avatar
Injectors aren't bad; however, the brake will hit hard.
Old 01-31-2015, 08:17 PM
jay0707's Avatar
some pic of mine
File Type: jpg
The following 2 users liked this post by jay0707:
KenB350z (01-31-2015), protoRDX (01-31-2015)
Old 01-31-2015, 08:22 PM
jay0707's Avatar
sorry for bad unclear pictures. took them on bad weather
Old 01-31-2015, 08:48 PM
KenB350z's Avatar
Carbon fiber son!
Old 02-01-2015, 03:58 PM
FLETCH
TheWrench116's Avatar
I'm running the 800cc DW injectors. and as long as you like the mods F#ck the rest. you drive it if you like it that's all that matters!
Old 02-01-2015, 04:14 PM
KenB350z's Avatar
800cc DW's here!
Old 02-01-2015, 09:12 PM
jay0707's Avatar
I can't wait for my ebc brakes to get here
Old 02-01-2015, 09:35 PM
FLETCH
I blew through mine in just over a year.
Old 02-01-2015, 10:50 PM
KenB350z's Avatar
Brakes?
Old 02-02-2015, 02:01 PM
FLETCH
yeah. I was pissed for the kind of money they ask. I put ceramic pads on and get free ones now. still have the EBC front rotors but the rear are shot and cant be used.
Old 02-02-2015, 02:11 PM
KenB350z's Avatar
Damn...
Old 01-10-2018, 02:16 PM
CSmoney28
CSmoney28's Avatar
I’m getting the same code, what cause the issue and how did you get it fixed? Thanks in advance buddy.
