dyno procedure???
Old May 12, 2014 | 09:08 PM
TheWrench116's Avatar
FLETCH
dyno procedure???
this goes out to those that have done dyno tuning. is it possible to just disconnect the rear drive shaft for tuning purposes as its only a 2 wheel dyno.
Old May 13, 2014 | 10:06 AM
bluecarbonfiber's Avatar
WTF?
yes you can.. you have to turn off the traction control when you do it. also your numbers will be squewed since your only going off the front wheels and not all 4
Old May 13, 2014 | 11:23 AM
Slow98teg's Avatar
You're in PA. I recommend visiting Innovative Motorworks in Carlisle. Derek does a great job. They have an awd mustang dyno so no need to disconnect anything. I've been slacking on putting mine on to get baseline numbers.
Old May 23, 2014 | 04:21 PM
FLETCH
260 whp 261wtq didn't adjust boost added 1degree to base timing and a little fuel that was all she wanted.
Old May 23, 2014 | 10:31 PM
WTF?
the real question now is.. will you add more boost? or why wasnt it added??
Old May 24, 2014 | 07:55 AM
FLETCH
need to understand how to use flash pro better then after I get the turbo modified by Blouch performance ill add boost. seems like this turbo is pretty much maxed out and I want my takeoff to be a good core for the next guy.
Old Jun 20, 2014 | 03:30 PM
mack1611's Avatar
Did you get your turbo modified yet?
Old Jun 20, 2014 | 05:10 PM
Tomtwtwtw's Avatar
Wait...so you made 260 to the wheels on AWD with the boost settings from the Hondata Flashpro baseline?
Old Jun 21, 2014 | 10:44 AM
FLETCH
didn't get the turbo yet and no I made 224 to the wheels with the base map and my entire mod list. but I did get a set of K24 stock cams the other day did we ever confirm them to fit?
Old Jun 21, 2014 | 01:32 PM
Tomtwtwtw's Avatar
Gotcha...that sounds much more realistic. Not that I don't want to see someone at 260. Keep it up!
Old Jun 21, 2014 | 01:55 PM
FLETCH
no I made 264 by the end of the session. I started at 224 with a base map and what used to be fully bolted. ( now we have cams and more goodies )
Old Jun 21, 2014 | 01:59 PM
FLETCH
double check but I think big hatch made more then me. I don't have a full exhaust just an RV-6 dp.
Old Jun 21, 2014 | 03:18 PM
Tomtwtwtw's Avatar
264 at what boost level though? Still only 14lb? If so did you manage to keep it at 14 at higher revs or did you gain all the power through timing and fuel adjustments? Just curious what the secret is to bringing the potential out of this engine.
Old Jun 21, 2014 | 06:41 PM
Slow98teg's Avatar
Small world. I sold you those cams.
Old Jun 21, 2014 | 06:51 PM
FLETCH
yes you did I could have picked them up on my way home on tues but they are here. kinda rusty but hopefully they clean up well. and yes the 264 number is with fuel and spark added only we didn't touch the boost settings. im not up on my flash pro enough to be able to add boost. im still a noob in the tuning a computer world.
Old Jun 21, 2014 | 07:12 PM
Slow98teg's Avatar
Pulled them out of my crv motor I'm building for my car. I don't know how long the motor sat. Came from a dealership.
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
ceb
ILX
Sep 27, 2015 10:56 AM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
mc1114
Sep 11, 2015 05:50 PM
HOWELLiNC
Sep 10, 2015 01:39 PM
