EBC Brakes - noise
EBC Brakes - noise
I installed 3gd rotors and yellow ebc pads this past week. I also installed the rotora front and rear braided lines while I was at it.
All seems good and the brakes work great, unfortunately, there's a significant noise coming from the wheels at speed. It's hard to explain, but it sounds like the locusts you can hear in the evening.
I was wondering if it might be the shims installed incorrectly. The stock pads had 2 shims on the inner pad and one on the outer pad. The EBC pads appear to come with 1 shim permanentaly affixed to the pads so I didn't reinstall the outer factory shim and added the 1 additional shim on the inner pad.
Anyone else have a similar experience or any ideas on what to check?
The noise goes away upon applying the brakes and is quite noticeable when driving above 5-10 mph with the windows open - especially when driving by the road dividers or under bridges where the sound can echo back.
Any help appreciated!
Yes, dimpled and slotted.
Yikes, I hope not, this is pretty loud, enough that I think others I pass on the road or in the parking garage will think something is wrong with my car. I did expect this when braking and it does, when I brake, you can hear the swooshing noise - but I didn't expect to be able to hear it over the wind and tire noise at 60mph.
Just to confirm, did you hear the noise to this degree?
I'm not 100% sure on the "swooshing" noise...but I was able to hear the "locusts" noise when I was driving next to a median, wall, or curb. If I drove in the middle lane on a 3-lane highway...I wouldn't hear the noise (I'm assuming because there was nothing for the sound to bounce off of back at me.
PM me if you need a reply
Ah yes, the 3GD rotors do make that wind noise. It's like you can hear the wind pass by each dimple/slot. It goes away when applying the brakes but then you get that whooshing sound.
It drove me crazy at first but I am getting used to mine as the noise gets drowned out pretty easily. Looks great but I'll be going for the silent "dashed" USR rotors next time.
haole kama'a-ina
I have the black-dash USR rotors on my GTI and they are much quieter than dimpled-slotted -- they make a low, rushing hum when applied -- not very noticable with windows up and not annoying with windows down.
ps, there is information about 3GD rotor noise on EBC's web-site.
joflewbyu2
10-08-2015 11:16 AM
4drviper
09-23-2015 09:00 PM
