9005 bulbs
Old Oct 8, 2008 | 07:30 AM
rpkrdx's Avatar
Question 9005 bulbs
Has anyone replaced their 9005 bulbs? i purchased the piaa 9005 but they would not go in any help Thanks
Old Oct 10, 2008 | 08:19 AM
Rexorg's Avatar
Are you sure you have 9005's and not 9006's? 9005 is a high beam bulb; 9006 is a low beam bulb. They both have the angled base. The info is on the bulb also. Sometimes the bulbs get put into the wrong box.
Old Oct 10, 2008 | 08:29 AM
buxtons's Avatar
9005 or HB3 is correct if you want to replace the high beam. If you are trying to replace the low then that is different. I guess just check if you are 1) putting them in the right place and 2) putting them in the right way. I know that sounds simple but sometimes the simple stuff gets overlooked.
Old Oct 10, 2008 | 09:59 AM
rpkrdx's Avatar
Hello, thanks but it was the metal ring with the two screws i just loosen the screws and twisted them in and retighten the screw and was done.
Old Nov 21, 2008 | 11:02 PM
littleblazer's Avatar
Put the bulb first then plug.
hashbrown
Feb 18, 2022 11:20 AM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
ripit
Sep 26, 2015 06:19 PM
eastcoastguy
Sep 23, 2015 06:29 AM
