9005 bulbs
Are you sure you have 9005's and not 9006's? 9005 is a high beam bulb; 9006 is a low beam bulb. They both have the angled base. The info is on the bulb also. Sometimes the bulbs get put into the wrong box.
9005 or HB3 is correct if you want to replace the high beam. If you are trying to replace the low then that is different. I guess just check if you are 1) putting them in the right place and 2) putting them in the right way. I know that sounds simple but sometimes the simple stuff gets overlooked.
ripit
Sep 26, 2015 06:19 PM
any help Thanks
