Where are the stereo's crossovers located?
Old Sep 9, 2020 | 10:01 AM
nemoD's Avatar
I have an 07 Tech and I'm about to swap out the four front door speakers. Does anyone know where the factory crossovers are located?
Thanks.
Old Sep 11, 2020 | 04:27 PM
nemoD's Avatar
Bump. I've taken a look at the Service Manual and can't find a reference to crossovers anywhere...but wouldn't crossovers be necessary for the OEM door speakers which are split between tweeters and woofers? Likewise, I've bought component replacement speakers with their own crossovers, but I don't see how to wire them in.
Thx.
Old Sep 12, 2020 | 12:57 AM
CSmoney28's Avatar
CSmoney28
Old Sep 12, 2020 | 09:28 AM
wspy's Avatar
2008 Acura RDX
I believe that the frequency split takes place in the head unit or amplifier. There is no separate conventional crossover component.
Old Sep 12, 2020 | 04:54 PM
nemoD's Avatar
Thanks Carmine, I also have the manual but I don't see any crossovers so I suspect that work is being done by the head unit or the amp...?
Old Sep 12, 2020 | 05:03 PM
nemoD's Avatar
wspy: I think you're right. So how do you upgrade the OEM tweeters, drivers and crossovers in the doors if you can't replace the OEM crossovers? Obviously I could just plug the speakers in and not use the new crossovers but isn't that a bad idea in terms of sound quality? FWIW, I bought JBL GX600Cs (once I narrowed down options that were both component speaker and 2 ohms, there's precious few options).
Thanks.
https://www.crutchfield.com/S-gJ8FlP...BL-GX600C.html
Old Sep 12, 2020 | 11:26 PM
CSmoney28's Avatar
CSmoney28
No problem, I hope you figure it out
Old Sep 14, 2020 | 12:24 PM
wspy's Avatar
2008 Acura RDX
Shouldn't really matter if you just install the JBLs without their crossover because the stock factory system has done it (freq split) already. Your main concern is that the impedance is correct at 2 ohms.
Old Feb 4, 2021 | 08:30 AM
stevolee's Avatar
4th Gear
Thanks.
Hi, I was just curious, but did you ever install the speakers without the passive crossover? If you did, how did it sound?
stevolee's Avatar
4th Gear
How much would this affect the sound quality and/or volume level?
Old Feb 4, 2021 | 10:06 AM
CSmoney28's Avatar
CSmoney28
Thanks, for the info trying to learn haven't installed this stuff since high school shop class lol
savclaude
Jan 21, 2013 01:42 PM
Westside_TL
Mar 18, 2012 04:35 PM
flags
Oct 25, 2010 04:48 PM
mbeebe
Jan 11, 2002 11:05 PM
