upgrade sound system
Old Aug 8, 2013 | 06:35 PM
Tizzil84's Avatar
I was just wondering if anybody's upgraded the factory subwoofer and amp but still kept the factory location without modifying anything except for putting in better equipment.
Old Mar 18, 2014 | 05:29 PM
TheWrench116's Avatar
FLETCH
do you mean just an upgraded sub? what about a better amp? ill have a walk through soon enough if you are a do it your selfer with some skill.
Old Mar 18, 2014 | 06:07 PM
bluecarbonfiber's Avatar
WTF?
bringing back the dead.. the original post was over 6 months ago =)
Old Mar 18, 2014 | 06:32 PM
Lanesky_OH8RDX's Avatar
Might as well keep the dead alive a smidge longer. I have also been wondering if this is feasible. I want to use this sub http://www.hertzaudiovideo.com/default_en.htm . As far as I have read the oem sub depth is 4" yes? this is 3.36" for an 8" sub with a max output of 600W. That is pretty good for a tiny sub. I have used Audison, Hertz and Focal in the past in my old Accord and the swapped into my 08 Si and have loved the sound and quality of their products so I want to stick with them. It would be really cool to be able to keep the oem sub box and grille so no one would be the wiser.
Old Mar 18, 2014 | 08:54 PM
FLETCH
peak numbers are deceiving look at RMS this is a much better means of measuring a subwoofers capacity. and aftermarket amps as well.
Old Mar 18, 2014 | 09:14 PM
Very good points. Seems the RMS is 200W which is still pretty good. Better than factory. Figure pairing that with a quality 5-channel amp and the tunes would pound quite nicely. I look forward to you're write up.
Old Mar 22, 2014 | 03:54 AM
dade03's Avatar
6th Gear
great post, I am a music lover and the sound system is so important to me, considering upgrade the factory subwoofer and amp for a while..
Old Apr 5, 2014 | 07:25 PM
dmaxv8's Avatar
I did our 14 rdx with a kicker comp 8" sub fit perfect in factory location then used a 300 w NVX amp cause it is super small fit behind side panel wired input siginal from old sub speaker wire & un hooked the active noise unit under the center consol.
Old Apr 6, 2014 | 08:25 AM
wspy's Avatar
2008 Acura RDX
So how does it sound? Does the little amp drive the sub well?
Old Apr 20, 2014 | 07:11 PM
dmaxv8's Avatar
amp puts out too much power for a single 8" I have the amp at 60% power & the bass setting in the radio at the netural spot at +2 on the bass the mirrors shake
mada51589
Jan 9, 2025 04:40 PM
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
jpadilla
3G RLX (2013+)
Nov 18, 2017 07:13 PM
Sep 15, 2015 06:44 PM
