upgrade sound system
Might as well keep the dead alive a smidge longer. I have also been wondering if this is feasible. I want to use this sub http://www.hertzaudiovideo.com/default_en.htm . As far as I have read the oem sub depth is 4" yes? this is 3.36" for an 8" sub with a max output of 600W. That is pretty good for a tiny sub. I have used Audison, Hertz and Focal in the past in my old Accord and the swapped into my 08 Si and have loved the sound and quality of their products so I want to stick with them. It would be really cool to be able to keep the oem sub box and grille so no one would be the wiser.
I did our 14 rdx with a kicker comp 8" sub fit perfect in factory location then used a 300 w NVX amp cause it is super small fit behind side panel wired input siginal from old sub speaker wire & un hooked the active noise unit under the center consol.
So how does it sound? Does the little amp drive the sub well?
mada51589
Jan 9, 2025 04:40 PM
rockyboy
Aug 4, 2024 10:35 AM
Sep 15, 2015 06:44 PM
