sub replacement
Old Aug 12, 2013 | 09:15 AM
TheWrench116's Avatar
FLETCH
sub replacement
JL Audio 8W3V3-4 8" Single 4-Ohm W3V3 Series Subwoofer
here is the critical info
8" 4-ohm subwoofer
mineral-filled polypropylene cone with nitrile-butylene rubber surround
power range: 50-250 watts RMS
peak power handling: 500 watts
frequency response: 28-250 Hz
sensitivity: 83.24 dB
top-mount depth: 4-9/16"
sealed box volume: 0.3 cubic feet
does any one know what the depth is from the mounting flange to the bottom of the factory sub box?
I could make it fit but it would be nice if there was only minor trimming required.
Old Aug 12, 2013 | 04:13 PM
Lanesky_OH8RDX's Avatar
I am very interested to find out if this will work. need more bass. lol.
Old Aug 14, 2013 | 01:33 PM
bcrow's Avatar
8" 4-ohm subwoofer
It would be a good idea to model that specific subwoofer in unibox or any of the other freeware sub/speaker modeling programs. You would have to have a ball park on the displacement of the stock subwoofer housing. I am also curious about what the stock wattage is for the sub- I think I read that the tech package sub has its own dedicated amp?
Old Aug 15, 2013 | 07:13 AM
wspy's Avatar
2008 Acura RDX
4 inches.
Old Aug 15, 2013 | 08:50 AM
FLETCH
GOD bless you sir!
Old Aug 18, 2013 | 02:13 PM
k23a1's Avatar
Let us know the results.
I wonder what else is out there for a direct replacement. I don't want/need amp/amp-kit/box, etc...I'm in the hunt for a direct replacement sub.
Old Aug 18, 2013 | 11:52 PM
FLETCH
http://www.crutchfield.com/App/Produ...s=01|575P3SD48
link to crutchfield comparison of direct fit replacement subs. might still need an amp to get the sub to sound good though.
Old Aug 19, 2013 | 10:30 AM
Mr Marco's Avatar
GOD bless you sir!
Old Aug 19, 2013 | 02:55 PM
Vividsi's Avatar
wow
Old Sep 4, 2013 | 10:24 AM
FLETCH
Originally Posted by Vividsi
wow
I know right. well the news is that this will be on the back burner till I get home because the local shop wants 100 to install the sub and another 100 to install the amp... but they'd cut me a break if I bought everything there... but ill resurrect this when I get home. in the mean time go show heeltoe some love!!!
Old Sep 4, 2013 | 02:48 PM
Vividsi's Avatar
yea they are a good company and came through on my exhaust system. Now I just have to decide if I'm getting bigger injectors and an intake to go with my flashpro.
Old Jan 11, 2014 | 09:01 AM
FLETCH
pics and write up to follow mid march.
so a few things changed going with a Rockford fosgate P2D48
8" subwoofer with dual 4-ohm voice coils
power range: 75-250 watts RMS (500 watts peak power)
frequency response: 39-250 Hz
top-mount depth: 4-13/16"
sealed box volume: 0.2-0.3 cubic feet
a Rockford fosgate 250X1 mono subwoofer amplifier
150 watts RMS x 1 at 4 ohms (250 watts RMS x 1 at 2 ohms) wired remote Punch Level Control included
frequency response: 20-250 Hz
preamp and speaker-level inputs preamp outputs
8-gauge power and ground leads and a 30-amp fuse recommended —no on-board fuses
11-1/4"W x 2"H x 7-3/8"D
and JL coaxial speakers C2 650X REARS
and JL component speakers C2 650 FRONTS
Attached Thumbnails sub replacement-1005930_767611856599934_397729487_n.jpg   sub replacement-971591_749030101791443_352442611_n.jpg   sub replacement-1512532_767053279989125_651693705_n.jpg
Old Jan 11, 2014 | 02:20 PM
bluecarbonfiber's Avatar
WTF?
are you going to redo the OEM box? or do a custom one in a different spot?
Old Jan 11, 2014 | 03:37 PM
FLETCH
ill try to reuse the factory box by adding a spacer to it.
Old Jan 14, 2014 | 07:19 PM
HBob's Avatar
Looking forward to the pics of the install.
Where are you going to place the amp?
Old Jan 14, 2014 | 07:33 PM
FLETCH
ill most likely make room in the spare tire well. if that fails I do have a welder. but it is a very small footprint amp so I should be able to find something.
Old Apr 2, 2014 | 03:23 PM
FLETCH
well the write up is coming along nicely ( its 3 pages in word so far with no pics... mods I might need help with how to post this much stuff ) but I think I'm going to put crossovers in the front doors and go ahead and swap out the tweeters. but the component woofers sound awesome in the front doors and the sub absolutely smokes the factory setup!!!
Old Apr 2, 2014 | 04:26 PM
WTF?
good to know.. cant wait to see the write up.. curious on what you did for the box
csmeance
Jan 7, 2026 06:25 PM
cycdaniel
Dec 17, 2019 10:58 AM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
niray9
Dec 8, 2015 07:34 PM
Billu99tl
Sep 13, 2015 11:30 AM
