Speaker Help
Old Dec 9, 2010 | 02:03 PM
DCIANDREW's Avatar
Speaker Help
2007 RDX
I've have now lost 3-door speakers since purchase. The last one just outside of warranty. The dealer has been no help. I want to replace my speakers but I can't find what to replace them with.
I know they are made from panasonic and are a 17-CM SDR speaker, but that hasn't helped, nor has searching through the forum.
Someone out there has to have replace these door speakers and I would like to know what they used, that doesn't require any mondifications. The Speaker sites haven't been much help either.
Thanks,
Old Dec 9, 2010 | 02:22 PM
Mr Marco's Avatar
Blown door speakers are a common Acura issue (across the board). There is an AZ member who swapped out to bigger and better door speakers; however he had to cut and remove the speaker grills and modify the door to get them to fit. I could not find his post, but I didn’t look that hard. I did find these three.
https://acurazine.com/forums/showthr...=690237&page=4
https://acurazine.com/forums/4g-tl-audio-bluetooth-electronics-navigation-294/driver-side-speaker-makes-noise-749118/
https://acurazine.com/forums/showthr...=738054&page=2
Check them out, they may be helpful.
Old Dec 9, 2010 | 03:08 PM
ParaSurfer1979's Avatar
Originally Posted by DCIANDREW
2007 RDX
Thanks,
Replace withe the only 2ohm aftermarker speaker. Infinity/JBL. both are owned by the Harmin Group. The infinity Reference speakers 6x.xx/set online or ebay will work just fine. They are 2-ways with adjustable tweeters and tweeter x-over. Most TL owners that wanna continue using the ELS amp choose these as you actually gain clarity and a tad more volume due to the fact the have 95db s/n ratio. They change the door speakers and the 3.5" center channel driver. All this comes out to be a great upgrade in sound. Going to any other speaker 4-ohm will drop the volume a decent amount.
Old Dec 13, 2010 | 09:17 AM
DCIANDREW's Avatar
Do these speakers require any fabrication? Reading these threads it seems that most have just done the warranty exchange. If I'm going to pay I don't want to pay for the same defective speakers.
Called Acura Customer cares, and have a case number. They won't admit to anything of course.
Does anyone have a copy of the tech bulletin for the speakers, that the could post?
Thanks,
Old Dec 13, 2010 | 01:30 PM
Thanks,
No fabrication involved other than most add dynamat to tighten the mid-bass from the mid-bass drivers.PM me if you have any other questions.
4drviper
Apr 23, 2025 07:13 PM
kb1rl
Sep 30, 2015 10:17 AM
polish_pat
Sep 25, 2015 12:24 PM
rboller
Sep 23, 2015 02:49 PM
