RDX Radio problem?
Old Mar 4, 2008 | 11:21 PM
tsao's Avatar
RDX Radio problem?
The RDX I was driving today seemed to have a little static on every radio station I tried.. Anyone know whats up with this?
Old Mar 4, 2008 | 11:33 PM
johnny99's Avatar
I don't have any problem with the radio. Maybe there's a loose wire in one of the speakers or the antenna connection?
Old Mar 5, 2008 | 09:27 AM
vrflyer's Avatar
Sounds like an Antenna issue to me, check it to be sure it's hand tight (screwed on).
Old Mar 5, 2008 | 12:48 PM
raul07RDX's Avatar
07 PWP RDX all day!
hello im new here but i had the same problem with the radio ,but CD's AND the IPOD seems to give you a crispy sound tho.
Old Oct 25, 2008 | 09:56 PM
stathis's Avatar
several FM stations in mine have static too
so I think it must be the antenna. My AM, XM, and CD sound is pretty good.
Please let us know what you found out.
Old Feb 20, 2009 | 11:42 AM
wd1541's Avatar
I had an 2005 MDX with the base model stereo. I had a lot of AM/FM reception issues. Also my XM sounded like it was playing in a tin can. I now have a 2008 RDX with Tech Package. I am much more pleased with the reception on both however the XM still sounds not as good as FM or CD or AUX.
It might not be a problem with your antenna but where you live. I notice in areas of South Florida there are a lot of pirated radio stations that only transmit for a few miles. When I am in an area with these stations the radio does get static and bleed over from the illegal radio stations. Cell phone towers, emergency radio bands (fire, EMS, Police), electric lines, etc.. can also interfere. All of these things including FM are starting to broadcast in a digital format.
At one time I was thinking of having a FM booster installed. Don't know if it would have worked.
I hope this helped a little.
Old Jan 4, 2015 | 06:13 PM
mkassa's Avatar
audio problem 2007 Acura RDX
I have audio problem on my 2007 Acura RDX both on radio abd cd no sound at all. Please help. Thanks
Old Jan 4, 2015 | 07:34 PM
hypnotini's Avatar
how cold out was it....mine crackle for a while till the warm up.
Old Jan 9, 2015 | 11:09 AM
GSJake's Avatar
Same here.. mine is really bad for the first 10 minutes when its super cold out.
After the car warms up good to go?
Old Feb 6, 2016 | 06:06 PM
firstyearRDX's Avatar
Radio Problems
My 2007 Tech Package radio "static" or speaker problems have been getting progressively worse. Last winter I couldn't hardly hear the radio when the temperature was below freezing but it would get better in a few minutes. This winter it is bad when the temperature is below about 50 and sometimes get better but still sounds like all the speakers are blown. Playing iPhone the speakers sound fine. Anyone had the same problem and found a solution?
Old Feb 9, 2016 | 09:42 AM
DRR98's Avatar
Did u try the advice given in post #3 above?
Old Jan 13, 2017 | 11:43 AM
wmassmann's Avatar
Have a similar problem. The sound is almost unrecognizable when it is cold outside, but gets better when the car warms up. The dealer wanted to replace the "Amplifier" for a cool $900. Yeah right!!
rockyboy
Aug 4, 2024 10:35 AM
kmawani
Feb 8, 2023 05:09 AM
1lowtc
1G RDX (2007-2012)
15
Nov 19, 2015 10:52 AM
DwDrummer
5G TLX Problems & Fixes
Sep 14, 2015 08:20 PM
012TL-GLM
Sep 11, 2015 12:40 PM
