How to run battery wire for CarPC thru RDX firewall?
Old Apr 22, 2007 | 08:43 PM
mihooper's Avatar
I'm looking for a "non-destructive" entry location to run a 10GA battery wire from my engine compartment to my interior to power my CarPC. Does anyone have any suggestions where I might look? My car is leased so I don't really want to "create" any new holes.... This install wire would be similar to someone adding an audio amp.
Old May 16, 2007 | 10:06 PM
sailor_david's Avatar
9th Gear
I have to do the same thing in the next few weeks. If you look on the passenger side, behind the glove box there is a rubber plug that also has a wiring harness passing through it. I suspect if you cut a small hole in the surrounding gasket you should be able to run a wire along side and then silcone the rubber up to make it waterproof. Let me know how you make out.
Sailor Dave
Old May 17, 2007 | 06:20 AM
mihooper's Avatar
Thanks David. I'll take a look and let you know how it works out.
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
04tler
Sep 10, 2015 01:13 PM
Phambam12
Sep 6, 2015 06:57 PM
