Drop in Sub
Old Jun 13, 2015 | 10:36 PM
Rinja's Avatar
Drop in Sub
im looking to upgrade my sub with a JL 8W3v3-4 and replace the stock sub and my question is will it fit cause of that big marget it has. i have not open up that area to look myself.... i have seen on the other topics that a Kicker Comp S fits
Old Jun 13, 2015 | 10:54 PM
KenB350z's Avatar
I'm sure you will have to modify the factory sub box, due to it being so thin.
Old Jun 13, 2015 | 11:02 PM
Rinja's Avatar
Thanks Ken i'll ask my guy if he can do that....... Just got this RDX from my dad so im trying to do some mods to it
Old Jun 13, 2015 | 11:33 PM
KenB350z's Avatar
No problem. I'm thinking about upgrading my sub as well. What are you future plans for the RDX?
Old Jun 13, 2015 | 11:40 PM
Rinja's Avatar
CPE -intake and maybe flash ecu if i can find a place nearby and BOV are on my mind right now
Old Jun 13, 2015 | 11:44 PM
KenB350z's Avatar
Very nice!
Old Jun 16, 2015 | 12:02 PM
TheWrench116's Avatar
FLETCH
no I will not fit. short answer. if you want something to be installed into the factory box I can do it though. I put a P3D28 in my factory box. its not perfect, in that I never repainted the wood that is visible. but a trim ring around it would also hide it too.
pm if you want to talk about the options. a few pics of the build/installation. and it works way better then the factory option!
but nowhere near as good as my 15.
Attached Thumbnails Drop in Sub-2014-03-14_00-03-37_89.jpg   Drop in Sub-2014-03-14_00-03-44_880.jpg   Drop in Sub-2014-03-14_00-04-11_290.jpg
Old Jun 17, 2015 | 03:01 PM
Rinja's Avatar
do you know the measurements for the drop in sub box
Old Jun 18, 2015 | 02:51 PM
FLETCH
You mean a drop in sub right?
Old Jun 18, 2015 | 02:52 PM
Rinja's Avatar
Yes
Old Jun 18, 2015 | 05:36 PM
FLETCH
Stock sub is 2 15/16 mounting depth.
Old Jun 24, 2015 | 09:01 PM
Rinja's Avatar
got my amp and cables in the mail today
Should be getting my Sub on Friday
Old Jun 26, 2015 | 09:53 PM
Rinja's Avatar
the sub i picked out hopefully i have time this sunday to get it put in
Old Aug 5, 2015 | 08:53 PM
DDTsx06's Avatar
any updates??
Old Aug 6, 2015 | 01:48 AM
Rinja's Avatar
Drop in Sub
I have it installed hits hard some times too hard that I hear metal rattle
Old Aug 6, 2015 | 01:49 AM
Rinja's Avatar
Drop in Sub
I'll upload some pics tomorrow
Old Aug 6, 2015 | 12:39 PM
Go Stros!
Can't wait to see it! also provide any tips or tricks you have, if you remember. lol
Old Aug 9, 2015 | 07:15 PM
Rinja's Avatar
and when i was putting it in i had to think of where to put the amp in but keep it looking stock
with the sub it was pretty much DROP in cause the mounting depth for my Kicker 8inch Comp RT is smaller then the stock mounting depth of 2 15/16
Old Aug 11, 2015 | 03:58 PM
Tomtwtwtw's Avatar
Got any pics of the sub mounted? I assume it looks exactly stock since the sub fit in, or were any modifications needed? Did this amp just run in-line with the feed that already goes to the sub, which if so I assume it means you can still control the sub output independently from the bass/treble from the radio controls?
Sorry for all the questions, it just appears you did exactly what I want - 100% stock looking upgrade that doesn't require any additional knobs or controls up front either!
Old Aug 12, 2015 | 05:49 PM
Rinja's Avatar
Drop in Sub
I converted the stock sub wires to rca and that line into the amp and the amp to the sub ... I can still control the sub setting in the eq
Old Aug 13, 2015 | 09:51 AM
Tomtwtwtw's Avatar
Awesome, thanks. I'm pretty noobish when it comes to wiring - where did you run the amp to for power? Did you have to connect straight to the battery or through a fuse somewhere? And either way, how did you go about routing the cable?
For converting to RCA, did you just strip the end of the wire and attach the RCA plugs to the end?
Old Aug 13, 2015 | 03:39 PM
Tomtwtwtw's Avatar
Also, which 8" did you go with? 40CWRT82 or 40CWRT81?
Old Aug 13, 2015 | 11:37 PM
Rinja's Avatar
Power is right from the battery of the car i got a speaker to rca cable and wire them together i got it off crutchfield site and for the sub i got the 40CWRT82.. thats a 2 ohm sub but since it a dual voice coil when you wire it up it will become 4ohms... you can get the 40CWRT81 and it would wire up to 2ohms which would push the amp right at the peak if you got the same amp i got too
Old Aug 14, 2015 | 09:00 AM
Tomtwtwtw's Avatar
Once again, thanks. So, one last question - what route did you follow in getting power from the battery to the amp? I saw the wiring kit you posted comes with the fuse so I assume that pretty much covers all needs (save for the RCA conversion you just mentioned).
Old Oct 12, 2015 | 07:22 AM
crxtype-r's Avatar
richard cranium
pic of the sub install in the box ?
Old Jan 4, 2016 | 08:52 PM
Rinja's Avatar
Sorry I don't own the rdx anymore. Picked up an EVO X
Old Apr 9, 2016 | 08:09 PM
xxiaze's Avatar
Subwork
Pioneer ts-sw2002d2 is a direct drop in except for new mounting holes being drilled with self tappers.<br/><br/>Just completed an audio makeover. <br/><br/>Sounds great.
Old May 26, 2016 | 07:08 PM
arcanexvi's Avatar
This is a semi-dead thread but the easiest I found was a Hertz low profile sub ESF205 (4 ohms). Sits easily in the factory enclosure.
Fair warning, the factory amp is 100W @ .7 ohms so you really can't use it. Yes, point 7 ohm... You're forced to use a mono amp. I've got mine running off factory controls using a small single channel marine amp that's 200W @ 4 ohm. Carved out a spot in the foam under the floor by the wheel well to house it and fished wires for power/signal.
Sounds great.
Old Oct 7, 2016 | 02:04 AM
Go Stros!
great information here. when you guys tap into the subwoofer wiring for the wire to RCA convertor, what wires are you guys tapping into? I believe I saw 5 total wires coming off of a plug connected to the stock sub box.. what colors did yall tap into? thanks!
Old Oct 7, 2016 | 08:59 AM
Tomtwtwtw's Avatar
Sounds great.
Did you happen to snap any pics during your install process? Also, any other connectors/adapters to wire the oem wiring into the amp? I'd love to do something like this, but I'm a super newbie on car audio.
Old Oct 10, 2016 | 09:14 AM
arcanexvi's Avatar
No sorry. I had the guys in my install bay at work doing the majority of the work for me. It only took them about 2 hours but they're professional installers. If I'd done it myself it probably would have taken 4-6 hrs.
Old Oct 10, 2016 | 09:06 PM
Go Stros!
can you ask your shop guys to see what wire they tapped for the for RCA convertor? any help is appreciated. thanks man!
Old Dec 22, 2016 | 08:09 PM
drakescherer's Avatar
I used the Green wire to provide RCA level input + and the Red wire to provide RCA level input -. In my situation I did not disconnect the original wiring but rather spliced directly into it to preserve the ability to remove and return to stock.
Usmcgrunt47
Oct 13, 2023 09:35 PM
emailnatec
29
Sep 28, 2018 04:27 PM
bluetl04
Aug 16, 2016 02:49 PM
us285126
Oct 2, 2015 02:03 PM
4drviper
Sep 23, 2015 07:42 PM
