Upgrading is fun
Old 03-09-2024, 12:48 PM
  #121
DaIll1's Avatar
Originally Posted by Tomtwtwtw
Lots of questions, such as what does the unit "/psi mean and why is the range of the graph 0.1 - 5869, with the readout being near the top most of the run? I do not think this is an apples to apples comparison here.
End of the day, a MAP sensor reads absolute pressure (hence the A and P of MAP), and if you had a car at sea level with the ignition on but engine off, you should get a reading of 14.7 psi from the MAP. Turbo can add to that, and vacuum will subtract from it. So, an engine under vacuum during, say engine braking, would see a MAP readout of something less than 14.7 psi.
Yes, I changed a setting and it went to the correct numbers.
Old 03-30-2024, 07:35 PM
  #122
DaIll1's Avatar
I blew out my back so I'm in the hospital recovering from 2 fusions and 2 laminectomies. I did find a place that would finish my exhaust, so I think I'll have them remove the dynomax muffler and just do a dual out the back and move the diverter valve to before the cat with a nascar style oval dump behind the front tire. Should add sound and yeehah. Being old and broken sucks hard, but hey, life could be worse. At least I have Jesus in my heart and I'm looking forward to the rapture very soon.
TLow4g (03-30-2024)
Old 03-30-2024, 10:57 PM
  #123
Sauce God
TLow4g's Avatar
hope you have a good recovery, will be praying for you
DaIll1 (03-31-2024)
Old 03-31-2024, 12:55 AM
  #124
DaIll1's Avatar
Thank you, prayers are always appreciated. If you want to hear about the rapture, listen to Pastor JD Farag's Bible prophecy sermon from 3/24/2024 on jdfarag.net. He doesn't give day or time, he only talks about the Hebrew holy days.
fireplace369
01-05-2021 07:19 PM
Rsuniar23
2G TL Photograph Gallery
01-27-2015 05:51 PM
jjdrivesajazz
3G TL Photograph Gallery
40
12-29-2012 11:46 AM
Roger555
85
01-21-2012 08:19 PM
Quick Reply: Upgrading is fun
