Upgrading is fun
Old Jan 5, 2022 | 11:32 PM
  #81
DaIll1's Avatar
Seat of pants wise, it pulls harder and smoother with intake mods. Streets have been wet or ice so I can't get a comparison datalog, yet.
Old Mar 1, 2022 | 11:26 AM
  #82
DaIll1's Avatar
Because of the way the back gets so muddy driving on wet roads I bought an air diverter for the lift gate from a C-RV knowing it would take a lot of work fitting it. Before starting on that I got a Gurney flap
Amazon Amazon
to see if it would disrupt the air enough to keep it cleaner. It keeps about 90% cleaner with very little work, so I'm pretty happy with it. Needed to use a heat gun to form the curves and it doesn't look horribad.
Old Mar 14, 2022 | 09:52 PM
  #83
DaIll1's Avatar
Boxed up my turbo to send to Blouch Performance Turbo tomorrow for the upgrade.
Old Apr 8, 2022 | 01:04 PM
  #84
DaIll1's Avatar
Since nobody makes a wheelchair lift for an RDX I had one custom made
Old Apr 13, 2022 | 12:28 PM
  #85
DaIll1's Avatar
Got a call from Blouch this morning, turbo is coming home. Even though I don't have a problem with engine mounts I'm going to replace all the old rubber stuff for the extra whorespuppies.
Old Apr 19, 2022 | 02:36 PM
  #86
DaIll1's Avatar
Yeehaw!
Old Apr 25, 2022 | 09:27 PM
  #87
tite681's Avatar
Awesome!
I wonder if this turbo setup will pass California smog with the stock tune.
Old Apr 25, 2022 | 10:56 PM
  #88
DaIll1's Avatar
Originally Posted by tite681
Awesome!
I think the big problem is the stock injectors are close to max and may lean you out. They wouldn't be able to see anything because it uses the factory turbo.
Hondata Flashpro has a CARB model so you can go with bigger injectors,
https://www.hondata.com/flashpro/flashpro-rdx-carb
Old May 11, 2022 | 08:44 PM
  #89
DaIll1's Avatar
Turbo installed. Now I need to learn how to raise or turn off the overboost. Getting on the freeway triggered the P2263 code ;(
Spools much faster and hits hard Tires struggle for traction, can't imagine what a FWD only would do.
Old May 11, 2022 | 10:57 PM
  #90
DaIll1's Avatar
Found the box to turn off P2263 in Calibration/ MISC.
Old May 14, 2022 | 09:43 PM
  #91
DaIll1's Avatar
Interesting point:
I gained 3 MPG and a considerable amount of torque.
Old May 24, 2022 | 11:43 AM
  #92
DaIll1's Avatar
Blouch turbo done after TL throttle body and RV6 down pipe, so I don't know what it would do alone, but WoW. I can't imagine a better upgrade for the money. I love how quickly the speedo needle climbs.
Old May 27, 2022 | 01:44 PM
  #93
DaIll1's Avatar
Since I use 92 octane with Aces IV treatment that brings octane to 95, I upped my boost to 2.2 bar. Showed my 4-ways to a mid '60's Camaro with very fat tires and a wumpity-bump idle.
Embarrassing old muscle cars in a 4 cylinder crossover is precious
Old Jun 15, 2022 | 11:58 PM
  #94
DaIll1's Avatar
Went to the dealer to buy parts for my upcoming intercooler upgrade. I figured since I've got 165k miles on it, I should put in new plugs and coils while the intercooler was off.
Dealer price was $1124.50, but because I took in the quote from https://acura.oempartsonline.com/?ut...Black-Friday-2 I paid $480.98. Well worth the effort.
Old Jun 22, 2022 | 12:45 PM
  #95
DaIll1's Avatar
Received my (used) ETS intercooler today, thank you Kevin2m4. This will save a bunch of work installing a front mount.
Old Jul 19, 2022 | 07:23 PM
  #96
DaIll1's Avatar
Had new plugs and coils put in while changing the intercooler today and they disconnected the HFL module for free.
Old Jul 26, 2022 | 04:12 PM
  #97
DaIll1's Avatar
I had an interesting problem come up. I wasn't sure if it was charging system or battery. It turned out to be the alternator.
It started off with the SHAWD light coming on, then the ASA flashing, followed by transmission not shifting right and slipping. Finally, the check charging system and battery lights came on.
As the battery voltage dropped it would drop the more 'thirsty' systems. I did however learn how a front wheel drive only unit would act with the extra power, smokey.
By the way, I took a print out of an order form for an alternator from OEM Parts Online (https://acura.oempartsonline.com/?ut...Black-Friday-2) and saved $170.00 at the dealership.
Old Aug 7, 2022 | 04:18 PM
  #98
DaIll1's Avatar
The BPT upgraded turbo spools later, but when it does, the dance begins. It really makes the SH-AWD work hard for traction and does the 4wd hopping
Does anyone know if there is a lower gear set available? I don't need it geared for 200 mph (theoretical) as most of my driving is city.
Old Sep 18, 2022 | 07:02 PM
  #99
DaIll1's Avatar
I installed a TurboSmart diverter valve https://www.turbosmart.com/product/k...mb-back-mazda/ yesterday.
They don't sell the tool to loosen the flange lock to clock the plumb back fitting, so I improvised. I stuck my needle nose pliers in a vice and it worked great.
Old Oct 8, 2022 | 12:22 PM
  #100
DaIll1's Avatar
Had some fun with a V6 Accord yesterday. Dead even, until the turbo spooled. After that it was mirror time.
He turned at the next light, oh the embarrassment of being spanked by a 4 cylinder SUV.
Old Dec 26, 2022 | 08:01 AM
  #101
DaIll1's Avatar
Upgrading my Gurney flap with this one.
https://cdn.shopify.com/s/files/1/04...g?v=1643215252
They have code for free shipping until 12/31/22
Old Jan 9, 2023 | 04:35 PM
  #102
DaIll1's Avatar
If you do order one, it comes folded in a small box and needs to be warmed to straighten.
Old Jan 11, 2023 | 01:44 AM
  #103
RRK0818's Avatar
Wish I could get an accurate fuel level on the gauge. With the BPT, rv6, Ets, ID 1054
Wish i could get an accurate fuel level. When full it shows 3/4 and when you run out it shows 1/4.
Have BPT, I D 1050s, rv6, Ets, 240amp alternator, DW 235 pump, D Rob tune.
Old Jan 11, 2023 | 10:14 AM
  #104
Tomtwtwtw's Avatar
Could this be related to the pump swap perhaps limiting the range of motion for the fuel level float in the tank? I'm not sure on the specifics for the RDX but I believe it can be located on the pump or pump bracket.
Old Jan 11, 2023 | 01:23 PM
  #105
DaIll1's Avatar
When I upgraded my fuel pump I bought a new pump assembly for a drop-in swap. My fuel gauge level was effected. At 3/4 level it takes 6 gallons to fill. I don't know what the empty reading is though, not really interested to find out.
Old Jan 11, 2023 | 07:37 PM
  #106
RRK0818's Avatar
Fuel Guage/ hondata
no, I changed everything related to the Guage BTW always worked flawlessly.
I suspect the hondata tune changed some algorithm and is the issue. Would like a work around.
Old Jan 12, 2023 | 01:00 AM
  #107
DaIll1's Avatar
ouch. I'm running Handata FlashPro with no issues on a base tune. I have a few things still to do before I get a tuner involved.
Old Mar 18, 2023 | 11:55 PM
  #108
DaIll1's Avatar
Finally got it tinted. 15% windshield visor wrapped around to doors using a 30% over 30%
Old Mar 24, 2023 | 08:25 PM
  #109
DaIll1's Avatar
Wheels came today. Enkei T6R 17x9 Matte Bronze
Old Apr 12, 2023 | 07:16 PM
  #110
DaIll1's Avatar
Got the wheels and tires installed
Old Apr 13, 2023 | 12:51 AM
  #111
DaIll1's Avatar
The tires are Michelin Pilot Sport A/S 4 in 275x40x17
In case you wonder why I chose bronze, I'm going to have it wrapped. It will be 2 tone, below the belt line Green Hell Mango above will be the same color bronze as the wheels.
Old Apr 13, 2023 | 10:07 AM
  #112
deepa1600's Avatar
That tire size is too small, you are about 2.5 inch low on total diameter as compared to factory. Your actual speed will be low as compared to what displays on the speedometer. Also you will rack up miles faster as revs/mile will go up.
Old Apr 13, 2023 | 11:57 AM
  #113
DaIll1's Avatar
As stated in an earlier post, the tire size was chosen to lower gear ratio. Yes, when the speedometer says 35 mph, gps says 30. I live in a city where the primary speed limit is 30 mph and I gained 5 MPG. Highway speed limit is 60 mph, so I'm not worried about it and I rarely drive highways. Besides, I'm aiming at a low 13, high 12 second quarter mile time. Now it's time for a tune
Old Apr 17, 2023 | 01:23 PM
  #114
DaIll1's Avatar
Ordered E-tune from InnovativeMotorWorks
Old Apr 17, 2023 | 11:03 PM
  #115
DaIll1's Avatar
Here's why I got the all seasons rather than the summers.
I've already ruined a set of summers. Driving on roads that cold makes them have a forever sound of mud tires. It fractures the inner structure of the tire and makes them loud and weak.
Old Apr 20, 2023 | 11:29 AM
  #116
Tomtwtwtw's Avatar
I have the exact same weather station.
Old Apr 20, 2023 | 06:11 PM
  #117
DaIll1's Avatar
My "outdoor" temperature is actually my garage temp.
Old Apr 25, 2023 | 04:23 AM
  #118
DaIll1's Avatar
in case you don't know what Green Hell Mango is, it's a Mercedes flat green with gold pearl, Green Hell referring to the Ring.
Old Aug 2, 2023 | 01:38 AM
  #119
DaIll1's Avatar
Sadly, I'm having an issue with the turbo responding correctly. I have all the hoses on order and will have them all replaced, but I'm wondering if the boost controller I bought online is restricting the boost. I'm going to have the boost controller from the Amazon turbo put on. Yes, I'm too broken to do the work myself. I never ran a log with the Amazon turbo, but it felt stronger (butt dyno wise), so I'm hoping it will react better. It should be putting out 18 lbs. and it's only reaching high 16's It's taking forever to get hosed, I ordered them the first week of June, so going on a month.
Old Aug 16, 2023 | 10:41 AM
  #120
DaIll1's Avatar
Hey y'all.
If you get one of these, have a friend or two help install it. Alone it's like wrestling a hot anaconda.
