fan comes on often
fan comes on often
hi all, anyone else have this issue with their rdx..
my fan seems to come on often, even when the car is cold when first starting..
im thinking it could be a couple things, low coolant or some sensor? any ideas?
1flossedm3 (11-19-2012)
I've had my 2011 RDX for almost 2 years and the other posters are right, the electric cooling fan cycles frequently no matter what the temperature. I believe it is more the auxillary electric cooling fan that runs when the air conditioner compressor is engaged, which can occur even in cold weather. I've had no problems. It's just a normal quirk of the vehicle, as far as I can tell.
From what I noticed in my RDX (and most of my other vehicles) the fans only cycle if the climate control is set to auto or a/c is forced on. It shouldn't be on when the motor is cold, once it reaches operating temps then it will keep it at that temp and if there is no air flow then the fans will kick in.
The fan should not be running or cycling on a cold motor with climate control off.
apparently it does it for everyone...
