Clock Issue
Old Jan 15, 2022 | 06:00 PM
  #41
RenoTL's Avatar
Originally Posted by phile
that’s because it only affects 2004-2012
Interesting because my car is right in the middle of this date range (2010 TL-SHAWD w/Tech) and I have not seen this problem. My clock and calendar are still correct.
Old Jan 15, 2022 | 06:03 PM
  #42
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
Believe it only impacts models that have navigation. Do you have navigation?
Old Jan 16, 2022 | 02:34 PM
  #43
RenoTL's Avatar
Yes I have navigation. As I said in my original reply, my car is a TECH model.
Old Jan 16, 2022 | 09:16 PM
  #44
comkb's Avatar
Originally Posted by Bamahooty
oh well, I missed that completely. There ya go.
thank you.
you doxxed yourself with the coordinates too 😂
Old Jan 17, 2022 | 07:33 PM
  #45
Shaker's Avatar
7th Gear
Originally Posted by stokesey
08 TL owner reporting in. This problem started for me on Jan 1, 2022 and my dash clock was 1 hour ahead for a few days. The GPS unit would not allow me to set the time, as others have reported. Now the dash clock is off by random amounts , today it was either 4 hours behind or 8 hour ahead.
I don't care about the clock, but my battery went dead a few days ago. Could GPS be running updates while the car is off?
I doubt. I would run battery parasitic draw test. Bluetooth HFL is common issue on 3rd gen TLs. It will drain battery in a day or two.
Old Jan 19, 2022 | 07:06 PM
  #46
stokesey's Avatar
Thanks, I already disconnected HFL when I bought the car. Right now car has no timing belt, so I will defer setting the clock and finding the electrical leech for later.
Old Jan 20, 2022 | 11:19 AM
  #47
dhldriver's Avatar
8th Gear
2010 Acura RDX
Originally Posted by Harry Hibler
I tried and that did not work.
battery reboot did nothing for me, either…what a pain it is, I go to setup screen and does nothing in clock adjust
Old Jan 20, 2022 | 11:34 PM
  #48
schen72's Avatar
Stop wasting your time trying to fix it. it is a code issue. There is no fix at the moment.
Old Jan 21, 2022 | 07:43 AM
  #49
NBP04TL4ME's Avatar
See post 143 in this thread - https://acurazine.com/forums/3g-tl-a.../#post16790065
Old Jan 24, 2022 | 09:44 AM
  #50
CCColtsicehockey's Avatar
That is some impressive work in post 143. Thankfully I don't drive the car enough to care about the time on mine. Would be super annoying though.
:rofl at Honda/Acura saying it will just fix itself in August. Like really that is the solution?
Old Jan 25, 2022 | 09:50 PM
  #51
RenoTL's Avatar
When I wrote this post on 01/15/22, the general impression was that my 2010 TL was included in the affected cars but today I read the official January, 2022 Acura Service Bulletin, B21120A Version 1 (http://www.urvi.net/forumfiles/SN/B21120A.PDF) on this issue and it shows it only affects 2007 - 2008 TLs. That explains why a 2010 TL like mine is not affected.
Old Jan 25, 2022 | 11:16 PM
  #52
Helmreich1's Avatar
3rd Gear
really not a solution is it?
Old Jan 26, 2022 | 10:25 AM
  #53
schen72's Avatar
No. Honda will either release a fix (which will involve DVDs) or we wait until August 2022.
Old Jan 26, 2022 | 10:29 AM
  #54
NBP04TL4ME's Avatar
I may be wrong but I don't see Honda spending a ton of $$$, time or resources on something that is supposedly going to fix itself in August, but that's just me.
Old Jan 26, 2022 | 02:34 PM
  #55
Tyrone503's Avatar
CDM
Acura has released this for the issue, which some have already figured out.
Old Jan 26, 2022 | 03:22 PM
  #56
MtnRDX's Avatar
I did not realize this was a problem until I cleaned my battery cables yesterday and then was completely pissed off it had the wrong time and it wouldn't take my manual entry.
Another completely stupid thing. This is right up there with your toddler can pick up your keys and unlink your key fob in a couple seconds. Then all your customized settings are gone and it will not allow you to adjust them. It just says error and there is zero mention of this anywhere in the manual or online. I had no idea the fob was unlinked and not allowing me to set my settings. I finally stumbled across a PDF for key fobs and solved it. That can also cause you not to be able to adjust your time. But that is not the issue here.
I will post the link/unlink proceedure anyways in case someone runs into clock issuess after Honda/Acura fixes this issue.
Linking/Unlinking the Remote Transmitters with DPMS
The remote transmitters 1 and 2 (identified on the back) are
linked to the DPMS, the climate control settings, the audio
settings, the customization menu (in the MID), navigation,
and illumination settings. To recall your settings in DPMS, the
remote transmitter must be linked to the system. Remote
transmitter 1 recalls Driver 1 settings, and remote transmitter
2 recalls Driver 2 settings.
To link and unlink the remote transmitters, press and hold the
Lock and Unlock buttons at the same time for about 1
second. The LED blinks twice to indicate linked and once to
indicate unlinked.
Old Jan 30, 2022 | 10:32 PM
  #57
Vtbx's Avatar
Does anyone know if I can bring my 08 RDX Tech to Honda Dealer to fix this? Or does it have to be an Acura Dealer? Thanks!
Old Jan 31, 2022 | 12:00 AM
  #58
schen72's Avatar
There is no fix as of yet. Honda/Acura might provide a fix or they might do nothing.
Old Jan 31, 2022 | 11:02 AM
  #59
CSmoney28's Avatar
CSmoney28
Exclamation
I manually changed my time in the GPS setting on my 2009 Tech
Old Jan 31, 2022 | 11:51 AM
  #60
schen72's Avatar
On my 2008, we aren't able to manually change the time. The bug prevents it.
Old Jan 31, 2022 | 02:10 PM
  #61
CSmoney28's Avatar
CSmoney28
Unhappy
Oh okay
Old Feb 6, 2022 | 08:51 AM
  #62
Curious3GTL's Avatar
So I have the orange disc that's been having this issue since January of 2021. Mine did NOT fix itself in August of last year. I was actually hoping it would fix itself in January of this year but instead everyone else's broke.
Is the base year in the orange disc 2001 or 2002? I also noticed my navigation broken date is a month off of the ones in the white discs. See below. So when is this going to fix itself if it ever will?
Old Feb 6, 2022 | 12:23 PM
  #63
Midnight Mystery's Avatar
Null and proud of it
I'm wondering if switching to a base clock could just allow us to set the time manually. I'm probably getting ahead of myself. Wiring would probably be a pita too. But it's a thought.
Old Mar 18, 2022 | 02:26 PM
  #64
Carbon Pearl's Avatar
They walk among us...
Add me to the pile. I was like why is my clock still wrong and I cannot reset it> I don't care about the calendar much but the time is an issue. I read in the 3G TL megathread for some it seemed to be fixed for some out of the blue. Mine was fine until last Sunday DST time change, Someone indicated pulling a fuse instead of the battery disconnect but I do not know if anyone has tried that for the RDX. I may see if that works but if not I guess we will see what August brings.
First the Fat Boys break up and now this...
Old Mar 22, 2022 | 05:06 PM
  #65
deepa1600's Avatar
Guys clock can be easily fixed by doing this: Disconnecting both battery terminals (negative first) at exactly 12:40 am/pm local time and reconnecting (positive first) them at 01:00 am/pm exactly local time. Then immediately turn ignition switch to ACC position and enter your radio and navigation codes. I fixed both clocks on my 2007 RDX and 2010 RL by this method. I found it on this website.
Old Aug 17, 2022 | 06:34 AM
  #66
Got in my car today and the clock did reset itself (albeit 2 hours behind) but I was finally able to reset my clock to the correct time. I will go back in and turn the auto DST off as stated upthread. Acura should have done better with this but at least I can start paying attention to my clock again.
Old Aug 17, 2022 | 11:51 AM
  #67
Helmreich1's Avatar
3rd Gear
Clock is working after I set the correct hour. Calendar now says January 1, 2003 - really!!!!??? ANd they want us to think they are high tech. LOL
Old Aug 22, 2022 | 08:33 PM
  #68
Mulvey's Avatar
5th Gear
Annoyed got in to my car last week and the time is 3 hours behide!?
Old Jun 6, 2024 | 07:12 PM
  #69
RDX_indy's Avatar
this stupid code is near impossible to diagnose. if you have ruled out the wastegate and the wastegate itself, i'd recommend a ECM tune to make it go away.
Slvr04TL
662
Jan 25, 2024 11:20 AM
acura1972
1G RDX Problems & Fixes
32
May 28, 2019 12:49 PM
Babnik
Jul 5, 2009 04:06 PM
Slvr04TL
Dec 5, 2007 09:47 AM
thehustler
Nov 11, 2006 11:27 PM
