Climate Control System Question
Old Apr 29, 2007 | 09:42 AM
Artie Ecks's Avatar
Hi Everyone-
I've been lurking on these boards for a few months, and I bought my RDX Tech a few weeks ago. Love it, love it, love it. This is my first post, other than my initial sign-in.
I have a question about the climate control system. The owner's manual says that "the system should be off for short periods only." But my wife and I enjoy driving with open windows when the weather allows it (like during this time of year!). The manual doesn't really give a reason as to why it should not be turned off often, other than mentioning that the fan should be running to keep stale air and mustiness from collecting. Obviously, this would not be an issue with open windows.
Does anyone know why they encourage running it virtually at all times?
Old Apr 29, 2007 | 02:05 PM
catnippants's Avatar
The only two things I've heard discussed are:
1. The AC compressor should be run fairly frequently to keep parts moving, seals lubricated, etc. - even in the winter.
2. Turning off the system limits the fresh air moving through the system and can fog up windows, allow bacteria to grow, etc.
True or not, I don't really know....sorry I don't have anything more definitive.
Mike
Old Apr 29, 2007 | 03:14 PM
asaldworth's Avatar
I think it has more to do with #2. If moisture gets in the system and stays there, it can grow mold or bacteria, which can smell really bad. I am not saying that you should run it all the time, but just once a week, or so.
Old May 1, 2007 | 06:22 PM
chipt911's Avatar
Can't imagine you'd have a problem with the windows open.
Old May 1, 2007 | 08:30 PM
Artie Ecks's Avatar
Thanks for the responses. I kind of figured it was a common sense sort of thing, but I wanted to be sure I wasn't missing anything.
Old May 2, 2007 | 03:18 AM
optik_rdx's Avatar
I noticed that even when in the off setting the system will blow air sometimes when driving down the highway.
Old May 2, 2007 | 07:03 AM
ozwaldo's Avatar
I have been getting a "musty" odor when I have the AC on and recirculating the air as opposed to letting outside air in. I asked about this during a service and the tech said to just use the fresh air setting.
Is anyone else smelling this in your RDX?
Old May 3, 2007 | 09:32 PM
XLR8R's Avatar
It's possible your cabin air filter may need changing. Once the filter captures enough contaminants it will put musty odor into the air passing through it.
The filter is located behind the glovebox and is easily accessed without tools.
Open the glovebox and unsnap the hook on the right side, then squeeze the glovebox sides together and lower it out of the way. The filter frame has two arrow shaped tabs on each side; push them in and slide out the filter. Put in the new one with the airflow arrows pointing down.
Old May 3, 2007 | 11:33 PM
mav238's Avatar
I agree. I changed the cabin filter in my TSX early this March, @ 30,000 km or 1.5 years.
Keep this filter changed once a year, and you should not have any issue with odor.
Old May 3, 2007 | 11:48 PM
jimmyR's Avatar
Oder build up is common with AC systems that allow moisture to remain in the system when the vehicle is shut down. I shut the compressor off a mile from home and allow fresh air to purge the system, and no oder.
Old May 5, 2007 | 06:57 PM
delron's Avatar
3rd Gear
Auto function
Did you notice if the recirculation light comes on if you turn the "auto" temp control feature on?
Old May 7, 2007 | 07:28 PM
neo1738's Avatar
2016 MDX Adv/SHAWD
not always
Old May 7, 2007 | 07:55 PM
johnny99's Avatar
Only if there is a big gap between the inside temp and desired temp. When the gap gets smaller, the recirc goes off.
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
PortlandRL
Sep 14, 2015 12:01 PM
datadr
Sep 12, 2015 09:12 PM
