Brake Threads?
Old Mar 5, 2012 | 10:31 AM
RangeRider49er's Avatar
Brake Threads?
Would someone tell me how to find the best threads on front and rear brake jobs for 2008 RDX? thanks.
Old Mar 5, 2012 | 11:49 AM
Looks like I'll start to answer my own question. The following thread seems to have some really good references.
https://acurazine.com/forums/3g-tl-2004-2008-93/brakes-caliper-o-h-pad-repl-hoses-bleed-disc-specs-park-brake-adj-3g-garage-d-041-a-578017/
Old Mar 5, 2012 | 11:55 AM
Here's another good brake job thread with great pictures: https://acurazine.com/forums/3g-tl-2004-2008-93/replacing-brakes-pictures-3g-garage-d-041-a-770166/
Old Mar 5, 2012 | 01:50 PM
I am also wondering if the pad shims which came with the original pads need to be used with newer/better pads? My brakes seem to be operating fine without the shims and the new pads came with metal surfaces for the new pads. I also used some silicon grease to lube the metal surfaces instead of brake grease.
Old Mar 6, 2012 | 08:47 AM
Another really good brake thread on painting the calipers: https://acurazine.com/forums/1g-rdx-diy-faq-161/diy-brake-caliper-painting-776569/
Old Mar 6, 2012 | 09:26 AM
Emergency brake adjustment thread: https://acurazine.com/forums/1g-rdx-diy-faq-161/adjust-emergency-brake-830192/ Also, the preceeding post has good pictures of the emergency brake/parking brake on the rear wheels.
Old Mar 9, 2012 | 10:27 AM
Brake Bleeding Thread:
https://acurazine.com/forums/1g-rdx-diy-faq-161/diy-pressure-bleeding-brakes-775757/
Old Mar 9, 2012 | 03:11 PM
Mr Marco's Avatar
Old Mar 11, 2012 | 06:54 PM
I know this is an Acura site but for those who have a Honda product like I do as well as an Acura, here is a really good video by Eric The Car Guy on doing the rear brakes on Honda's with the built-in emergency brake attached to the brake piston assembly:
This is a very well done video with lots of good explanations of how to handle the brake pistons with the slots in them, i.e. Honda rear brakes. Thanks Eric The Car Guy!
Old Mar 12, 2012 | 10:56 AM
Note on previous post! When retracting the brake piston on the Honda rear brakes, you may have to do what The Car Guy did in that video to get the piston to retract by rotating it clockwise with an appropriate tool while crimping (carefully) the brake fluid supply line and then opening the brake bleeder valve to allow the brake fluid to drain into a container while the piston is retracting. The Car Guy had this problem in the video and explains that it is done to avoid possible damage to the ABS! He had to remove the bleeder valve and clean it out before it would work correctly. I have seen some posts that mention that their brake piston retracting tools did not work and this is probably why they didn't work as expected.
mada51589
Jan 9, 2025 04:40 PM
Aug 15, 2019 12:58 PM
heykosal
1G RDX Problems & Fixes
Feb 27, 2016 06:43 PM
HOWELLiNC
Sep 10, 2015 01:39 PM
mav888
1G RDX (2007-2012)
Sep 8, 2015 11:49 AM
