Airbag light
Old Jul 1, 2020 | 05:00 PM
NaturalFlavored's Avatar
Airbag light
I've been reading and trying different things I've read in the community, my airbag light is intermittent. My seat belt light comes on with the airbag light, I've cycled the key etc.
has anyone had this issue? Any fixes? Where's all the connectors are at I'll try cleaning out the dust on them.
I work at the mines dust blow all day.
Old Jul 13, 2020 | 12:00 AM
Seriously I'm the only one who ever had this issue and no one has any help or info or insight??
Old Jul 13, 2020 | 02:20 AM
Midnight Mystery's Avatar
Null and proud of it
Hook up an OBD scanner. It's probably just an airbag sensor.
Old Jul 13, 2020 | 08:52 PM
KostaWitDaMosta's Avatar
Next time the light comes on, head to an AutoZone or similar and have the code read for free. That's going to be the starting point
Old Jul 13, 2020 | 09:33 PM
It stays on everytime I start the car, hooked up an obd2 and it won't show an error. It doesn't throw the airbag error until I start the car even then still doesn't show on the reader.
Old Jul 14, 2020 | 08:12 AM
Your OBD2 scanner might just be looking for generic emissions related codes. A factory level scantool like snap on or autel might be needed to read codes from the airbag module
Old Jul 14, 2020 | 10:02 PM
I guess they don't have an srs obd2 reader, wasn't showing up on theirs either. I'm just going to go through and check all connections tomorrow. Clean and check wiring, thanks all if you can help out where the connections are for the ones under the dashboard much appreciated.
also I have to pay for my front bumper to be fixed someone hit it and left. So now I have to pay for it to be painted.
Old Jul 14, 2020 | 11:45 PM
csmeance's Avatar
if the seatbelt light is not going out, the code may be recorded and can be read with a higher end scanner or HDS (Honda diagnostic system)
The seatbelt should be covered for 15yrs or 150k miles whatever comes first
Old Jul 15, 2020 | 12:48 AM
Not the seatbelt, I get a seatbelt alarm/ message on the cluster when I unbuckle. I tried that to make sure that wasn't it.
Old Jul 30, 2020 | 11:02 AM
Ok I got the code for it, 32-21 (permanent) increased resistance in passenger side airbag inflator.
VIN isn't part of the recall so how would I go about fixing this without paying an arm and a leg from the dealership.
Old Aug 4, 2020 | 01:38 PM
Fixed hopefully for good. Still trying to figure out what caused it, I just jostled the seat really good when the connections looked good and the light went off. Something was loose but don't know what.
ohbabbbay
Nov 10, 2024 10:00 AM
skippyTL
Oct 15, 2012 05:46 PM
Oh1TypeS
Jan 21, 2008 07:33 PM
arjjra
1G TSX Problems & Fixes
Nov 30, 2007 04:51 PM
nycvr6
Aug 21, 2001 07:23 PM
