AfterMarket Wheels & TPMS
Old Jun 7, 2008 | 06:10 AM
wspy's Avatar
2008 Acura RDX
I was wondering how the TPMS on the RDX works / is set up etc. I'm waiting on some new 20 inchers and I am a little concerned about this
Is this some gadet that you remove from the stock wheels and reinstall on the new one or what
Old Jun 7, 2008 | 09:39 AM
SinCity's Avatar
You can remove the stock sensors and place them on the AM wheels. From what I read so far, there hasn't been an issue with fitment. I just purchased a new set of sensors for my MRRs. This was I can easilly swap wheels back and forth if needed.
Old Jun 7, 2008 | 03:08 PM
wspy's Avatar
2008 Acura RDX
Ok. So what or where are these sensors located on the wheel?
Old Jun 8, 2008 | 12:14 AM
Patronus's Avatar
The sensors are located just inside the valve stem hole. The TPMS sensor is part of a piece that includes the valve stem as one piece. You insert the assembly into the valve stem hole in the wheel (from the inside, obviously), screw a nut on from the outside (obviously) and the assembly is done.
Old Jun 8, 2008 | 02:26 PM
wspy's Avatar
2008 Acura RDX
Oh ok. Thanks a mill !
Old Jun 9, 2008 | 07:13 AM
wspy's Avatar
2008 Acura RDX
Anyone know if the TPMS sonsors from an '07 MDX are compatible with the '08 RDX? I found a web site that sells the ones for the MDX.
Old Jun 9, 2008 | 09:08 AM
SinCity's Avatar
I believe they are different. You should be able to pick up a set for around $100 shipped from Ebay. I paid $105 shipped for new ones.
Old Jun 11, 2008 | 08:41 AM
wspy's Avatar
2008 Acura RDX
Researching
Old Jun 11, 2008 | 08:42 AM
wspy's Avatar
2008 Acura RDX
I did a little more searching and they had the ones for the RDX. Turns out that they are listed under the same part #. 42753-STK-A02
bailey24
Nov 21, 2015 08:43 PM
lland
Oct 4, 2015 04:47 PM
GhostTL09
Sep 19, 2015 01:57 PM
christopher1
3G MDX (2014-2020)
Sep 10, 2015 06:43 PM
trinikidcl
Sep 4, 2015 12:56 AM
