Very Odd Stalling In Idle. Any Thoughts?
Old Feb 1, 2010 | 06:40 PM
Orpheus333's Avatar
3rd Gear
Hi, I own a 1998 3.0L Cl with 175K and virtually no problems for 2 years. Saturday morning my car started acting very strange. It will start up but then quickly die in idle. If the gas pedal is pressed the car will start and run until the pedal is released, then it dies. It took it for a slow drive to see if it would run better when warm but it shifts really bad. It got to almost 3000RPM before shifting into 2nd during a slow accel. The RPMs will drop to zero, even when the car is in gear, if the gas pedal is released. No codes are being given. Cleaned the IACV and throttle body, no luck. It just suddenly began to do this... no warning signs. Could the IACV have gone bad? Is there a way to test it? What could be the issue? Thanks in advance for any help.
Ben
Old Sep 12, 2012 | 09:58 PM
bossanova5's Avatar
I'm having the same problem with my 97 3.0 did you figure out what it was?
Thanks in advance
Old Sep 13, 2012 | 12:12 AM
pitbullLOVER's Avatar
user & abuser
sooooooo many similar issues in the past couple months, their is a host of things that im just going to throw out their but it may not even be one, these are just the ones that have been like yours.
-ignition switch (thing the key goes into, they are notoriouse problems)
-ignition module (in distributor)
-ignition coil (beside the distributor)
might be something elce im just trying to give you idea.
Old Sep 13, 2012 | 07:05 AM
timeizmoney22's Avatar
Ben
My 3.0 has been shifting after 3k from first to second for about 10k miles now lol! Or if I barely give it gas it will shift early as hell with a slight lurch.
Old Sep 13, 2012 | 08:51 AM
user & abuser
for both of you in the shifting department, i used to thinke fluid changes were all one could do but take off your shift solenoids and clean them. there is a screen on the one and it can gum up.
SidhuSaaB
May 30, 2020 12:40 AM
Skirmich
Oct 1, 2015 12:59 PM
xsilverhawkx
Sep 28, 2015 06:51 PM
MilanoRedDashR
Sep 24, 2015 11:04 PM
mellsonnj
Sep 24, 2015 04:42 PM
