tranny problem
Old Nov 11, 2011 | 03:40 PM
porcho's Avatar
5th Gear
tranny problem
hi everyone new here,i have a 1997 acura cl 3.0 auto 189xxx.
the problem when is cold (first start) the harsh shifting bad and the soon warm up runs perfect all day.
i change the fluid with acura brand and still doing,my friends told me may be the solenoids...
any help i appreciated, thanks carlos
Old Nov 13, 2011 | 01:47 PM
udee's Avatar
98 3.0CL
It probably not your Solenoids! I have a 98 with 270xxx it does the same! Just let your car warm up a bit before you take off! Our cars are old! Be gentle she will last longer! Change fluids regularly it will help prolong the life of your car! I have taken my car to different places everyone says the same thing "just let it warm up bro"
Old Nov 13, 2011 | 08:34 PM
JDMCRX's Avatar
Clean all your silnoid filter screens. This sounds like there clogged. Only prob is if the valve body filter is clogged you got to strip the trans.
Old Nov 17, 2011 | 12:01 PM
porcho's Avatar
5th Gear
thanks a lot udee.
Old Nov 17, 2011 | 12:04 PM
porcho's Avatar
5th Gear
thank u jdm i will do that
Old Nov 17, 2011 | 02:12 PM
JDMCRX's Avatar
I did a write up with pics if u search my name
Old Jan 12, 2012 | 01:49 PM
j85alicia's Avatar
i am having the same exact problem. did you ever find a fix? did simply letting your car warm up in the ams help?
Old Jan 17, 2012 | 01:56 PM
Project_CLean's Avatar
MMkay.
^that does help. Changing your fluid does too; with a different type. The Z-1 fluid oxidizes quickly,thickening the mixture and therefore making it harder for the Solenoids/Screens. Cleaning and a flush/fill should help.
Pham Alvan
May 18, 2021 06:48 AM
SidhuSaaB
May 30, 2020 12:40 AM
Pham Alvan
Mar 16, 2016 09:17 AM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
