Power Steering??
Old Dec 6, 2011 | 12:07 AM
Gigolo's Avatar
1999 Acura CL 2.3
Power Steering??
did my power steering just crap out??
its making that "whining" sound when turning left or right.(like rubbing a wet ballon)..
i think it started as a small leak and now that its colder out if finally crapped out..(not positive but i think so)
curious...
also is it really dangerous to drive with it bad or empty??
i will have it fixed but just cant do it this week...
thanx
Old Dec 6, 2011 | 07:37 AM
saiko_cl_duck's Avatar
sounds like the power steering did go out, sorry. I've driven a car w/o pwr steering working, but it's not exactly fun nor that safe. If you have to make a quick movement your not going to make it happen.
Old Dec 6, 2011 | 03:33 PM
Gigolo's Avatar
1999 Acura CL 2.3
ok...figured sumthn.....i was about to go out and get sum lucas stop leak just for a temp solutution but like the dum a$$ i am i cant figure out which is the power steering container..lol
i looked to see if any belts were broken but i didnt see any so that appears ok...
i guess ill drive extra carefully and in a straight line with as little reversing as possible until i get it fixed.im due for a oil change next 600 miles so ill get it fixed when i get that done
Old Dec 6, 2011 | 08:57 PM
Gigolo's Avatar
1999 Acura CL 2.3
i found this on the net..
but it still doesnt point to where to put the fluid
http://www.justanswer.com/acura/5a6d...d-working.html
can anybody point out which reservoir is it?
Old Dec 6, 2011 | 10:20 PM
this is it, it's on the left side for 3.0. But look for a plastic cylinder with a red cap on top.
Old Dec 7, 2011 | 02:53 PM
Gigolo's Avatar
1999 Acura CL 2.3
yup..thanx man..
also saw this vid...i wonder if this O ring issue is common with CL's
Old Dec 7, 2011 | 09:55 PM
Gigolo's Avatar
1999 Acura CL 2.3
is this product safe to use in my case??
http://www.lucasoil.com/products/dis...tid=9&loc=show
should i use 1 bottle of regular honda/acura fluid before i use this or after or at all??
Old Jan 11, 2012 | 11:08 AM
ExShinobi's Avatar
if anything, its just low fluid. i know im way late on this post, but if u had a leak, stop the leak. low fluid in the resevoir will make that whining sound when turning the wheel! also, make sure the fluid aint all nasty and black, thats never any good and will kill the pump pretty quick!
Old Jan 17, 2012 | 02:00 PM
Project_CLean's Avatar
MMkay.
I had this same problem on my old CL; if fluid is normal then pump is probably bad. If its low or leaking try checking the Cooler up front behind the bumper.. you know; the loopy thing. There's a couple of rubber hoses there that deteriorate over time and can cause a major leak.
Acura604
20
Aug 5, 2017 12:55 AM
Jul 16, 2017 07:33 AM
Euro4gen
Dec 12, 2015 03:14 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
